Old 06-08-2020, 09:04 PM   #1
41panelmark
41panelmark's Avatar
Default Electric Wiper motor (Vintique)
Does anyone have a Vintique wiper motor installed in their 40? I bought one to use however the instructions are slim at best and the bracket does not seem to be set in the correct position to work with the existing mounts. Photos and diagrams would be very helpful.
Thanks in advance.
41panelmark is offline   Reply With Quote
Old 06-08-2020, 09:37 PM   #2
A bones
A bones's Avatar
Default Re: Electric Wiper motor (Vintique)
I really am sorry to bring this advice. Is there a chance you could get a return refund. I know. However...
Enjoy yer day. Tom
Hate can't fix what it started.
A bones is offline   Reply With Quote
Old 06-08-2020, 10:29 PM   #3
fordor41
fordor41's Avatar
I know Vintiques instructions aren't very clear. Installed their wiper motor in my '41. Laying on the floor, looking up , trying to figure out if the drawing is upside down or what.
Finally just mounted the motor and tweeked the brackets to fit.
fordor41 is offline   Reply With Quote
Old 06-09-2020, 08:19 AM   #4
Zax40
Zax40's Avatar
Thanks in advance.
Mine may be Vintique, not sure. Do you have a pic of the unit or a link that shows it? I can snap some pics after work today.
Zax40 is offline   Reply With Quote
Old 06-09-2020, 08:34 AM   #5
51504bat
51504bat's Avatar
Sorry Mark but a Newport Engineering wiper would have been a better choice. The unit I installed in my '54 Ranch Wagon came with clear instructions and I was able to install it with a minimum amount of four letter words.
Old 06-09-2020, 09:38 PM   #6
41panelmark
Ahh heck, I should have checked with everyone here first. I will see if I can make this work without much trouble, if not Newport or something similar.
Old 06-09-2020, 09:40 PM   #7
41panelmark
Here is a photo of the unit.
Old 06-09-2020, 10:28 PM   #8
51504bat
51504bat's Avatar
I'm sure you'll be able to figure it out. Assuming you already contacted Vintique tech support? You might also check over on the Hamb to see if anyone has any ideas.
Old 06-09-2020, 11:57 PM   #9
Newc
Newc's Avatar
Yes; That is a commercial motor and we have them in the local buses. Will work, but some fiddling is required. the 'stroke' can be too long and too powerful. Newc
Old 06-10-2020, 09:24 AM   #10
TJ
TJ's Avatar
Your original bracket for the vacuum wiper sits flat against the firewall. there's a cutout in the firewall pad to allow the bracket to sit flat. You may have to trim the pad to get the repo bracket to sit flat. I installed one of those units sometime back and I did have to trim the pad,
The stock holes in the firewall should line up for the repo bracket.
