05-23-2020, 07:30 AM | #1 |
Modern distributor cap
Is there a difference in performance of the modern style distributor cap and wires versus the original cap and bronze spark plug connectors?
05-23-2020, 07:41 AM | #2 |
Re: Modern distributor cap
Quite a bit of difference. With the modern cap the engine won't misfire when it gets wet, modern wires won't emit huge amounts of RFI when the car is running.
Frank |
05-23-2020, 09:27 AM | #3 |
But the modern caps just dont look right to me.
05-23-2020, 09:42 AM | #4 |
I prefer the original distributor cap , first for the original look . The gaps can be measured between the rotor tip and the 4 contacts in the distributor cap . The 4 contacts can be filed for equal gaps at all four contacts in the original cap . I consider equal gaps as part of a tune up . I prefer a gap of .035 between the rotor tip and the contacts in the cap for equal and hotter spark at all cylinders . Measuring gaps at the rotor tip isn't possible with the modern style distributor cap .
05-23-2020, 11:19 AM | #5 |
Thanks guys. I agree with the original look and honestly I hadn’t thought about the ability to check and adjust the gaps. If there is/was a significant performance increase, I was thinking about going with the modern cap and wires. Stay safe.
05-23-2020, 12:06 PM | #6 |
I know the voices aren't real but damn they have some good ideas! |
05-23-2020, 12:12 PM | #7 |
Just thinking,,, if electricity travels at roughly 11, 628 inches per second how long does it take for the spark to jump .025 or .035?
I noticed the harder I work the luckier I get! |
05-23-2020, 01:38 PM | #8 | |
While it is possible to measure and adjust air gaps with the original model A or B distributor caps, I don't see how measuring air gaps would be possible with a modern style distributor cap . Air gap distance won't make a day and night difference in performance but there does need to be air gaps for the spark to jump . Ford recommended gaps of twenty five thousands at the rotor tip . More gap to a certain point will increase spark intensity . I set mine at thirty five thousands . I believe that equal size air gaps at the rotor tip will send equal spark to each cylinder for better performance . |
05-23-2020, 02:09 PM | #9 |
I like putting a clear distributor cap on the distributor body. At night the little ones like to see the "sparklers". You can't do that with a modern distributor cap.
05-23-2020, 04:58 PM | #10 | |
Sort of like painting the engine red - proven to make the car go faster. Joe K
Shudda kept the horse. |
05-23-2020, 05:00 PM | #11 |
Who sells the modern style distributor cap and wires ?? Thank you !
05-23-2020, 06:23 PM | #12 |
Snyder's has them. https://www.snydersantiqueauto.com/P...-a/distributor
05-24-2020, 09:50 AM | #13 |
If the original style distributor cap body and cap was made as one part , you would lose the ability to measure and adjust the air gaps . I've used and found NO advantage to a modern style distributor cap when used with the original model A distributor .
05-24-2020, 10:14 AM | #14 |
No difference in performance.
05-24-2020, 10:37 AM | #15 |
Maybe no better but to use some heads like my Lion Speed, you have to go with the modern style cap and wires
05-24-2020, 02:45 PM | #16 |
Mikes was selling the “A” style cap that could be used with modern cables.
05-24-2020, 04:34 PM | #17 |
I have an original style cap and have driven long miles in the rain and never had an engine miss from the bronze spark plug connectors.
John
Welcome each day |
05-24-2020, 08:36 PM | #18 |
I have one of those on my engine. They are made by Renner’s Corner which is where I bought mine. Works / looks great. Best of both worlds??
05-24-2020, 09:09 PM | #19 |
Back in the '60's I had a clear modern cap. You could watch the rotor spin and points break.
1921 Runabout 1930 Tudor Early 1930 AA Speed costs money. How fast do you want to go? |
05-25-2020, 02:31 AM | #20 | |
They just don't look the same.....
And all the clear cap comments make me wonder how hard it'd be to make a mould and cast one in resin.
<Link> This is how we roll<Link> "I'm Convinced that no one really reads posts anymore; they just fabricate what they think the post says then ramble on about red herrings."--Bob Outcasts rules of old cars #1 Fun is imperative, mainstream is overrated #2 If they think it is impossible, prove them wrong #3 If the science says it impossible you are not being creative enough. #4 No shame in recreating something you never had #5 If it were not for the law & physics you would be unstoppable |
