03-20-2020, 11:03 AM | #1 |
36 Ford fordor sedan dash gauges removal
I need to remove my amp meter/temp gauge cluster to replace. Do I need to remove the dash? If so, how? Thanks for any suggestions!
03-20-2020, 11:20 AM | #2 |
Re: 36 Ford fordor sedan dash gauges removal
We can probably assume correctly that i's a Ford. Knowing the year would be nice.
03-20-2020, 11:24 AM | #3 |
As thread states - 36 Ford
03-20-2020, 11:38 AM | #4 |
No need to remove the dash.There's two nuts behind the gauge that hold it to the dash. Disconnect the battery first though.
03-20-2020, 11:55 AM | #5 |
Much easier to remove the speedometer then you have easy access thru that hole without fiddling from under the dash.
03-20-2020, 05:50 PM | #6 |
03-20-2020, 06:11 PM | #7 |
deuce lover is spot on here. Taking out the speedo makes this job much easier. Expect to drop a nut/washer or three so take care to make a place to catch those buggers. 1/4 inch ratchet with appropriate extensions will help alternating with box/combo wrench.
Be aware there are two light bulbs at 11 and 1 o'clock on the speedo as well as the easily removed speedo drive cable. I'd advise you be gentle with the temp gauge because it's not really a wire but a liquid filled tube and is easily f-ed up. While all this kit is out take time to clean the inside of the instrument glass with a q-tip reached in from behind, and carefully/gently clean the green plastic 'window' pieces that let light into the dials from the tops. I've heard of folks replacing that stuff with Sprite or Mtn. Dew bottle plastic.
-Jeff H Have you thought about supporting the Early Ford V-8 Foundation Museum? |
