Old 11-11-2020, 08:03 PM   #1
J35ford
J35ford's Avatar
Default Steering wheel help
Can anyone help identify what steering wheel this may be from. This was in my 1935 truck. It is in decent shape and I am thinking of restoring it. I need to locate the center horn piece but have no idea what this may have come out of or if it is original to the truck.
File Type: jpeg E5FD616B-82C7-4E36-BA7D-61CEB977ACFC.jpeg (167.7 KB, 105 views)
J35ford is offline   Reply With Quote
Old 11-11-2020, 08:32 PM   #2
Newc
Newc's Avatar
Default Re: Steering wheel help
that maybe a '53 power steering wheel/ Crestliner wheel. Valuable when restored needs the horn ring Newc
Old 11-11-2020, 08:39 PM   #3
V8ER
'54 Ford accessory steering wheel. The '52/'53 version was all white. The correct horn ring will likely be very hard to find.
V8ER is offline   Reply With Quote
Old 11-11-2020, 10:31 PM   #4
Ardun
Ardun's Avatar
It’s a 53-54 Ford Accessory Steering Wheel. Looks like the center hub has been modified for earlier Ford steering shaft, like your 35, with a keyway. Not worth much in current condition especially without a horn ring.
Ardun is offline   Reply With Quote
Old 11-11-2020, 10:55 PM   #5
19Fordy
19Fordy's Avatar
Restored wheels are very expensive. $3-4K in todays market.
It cost about $1300 to have it recast. Then add $1200 more for an excellent good horn ring if you can find one.
https://www.google.com/search?q=1953...hrome&ie=UTF-8
Old 11-12-2020, 11:14 AM   #6
Ardun
Ardun's Avatar
Got this recast for $600.00. Great job.
File Type: jpg 0704E811-51F4-4FDD-B81A-97A27CACF089.jpg (68.1 KB, 59 views)
Old 11-12-2020, 01:36 PM   #7
TJ
TJ's Avatar
That was a bargain. Who did it for you?
Old 11-12-2020, 02:08 PM   #8
19Fordy
19Fordy's Avatar
Ardun, You did good, especially for a "recast'. Ten years ago I paid $1100 to have this recast. Then add another $400 for rechroming the pot metal horn ring and the trim pieces if you're lucky enough to have them. Then $100 for center emblem.
Old 11-12-2020, 06:37 PM   #9
hop up
hop up's Avatar
A reproduction horn ring is sold by limeworks and is a nice piece
Wanted flathead speed equipment Thanks
hop up is offline   Reply With Quote
Old 11-12-2020, 07:49 PM   #10
J35ford
J35ford's Avatar
Well I guess for now it will be a nice wall hanger. 👍
Old 11-14-2020, 11:42 AM   #11
Automotive Stud
Automotive Stud's Avatar
It doesn't look to be in bad enough shape to need to be recast. And I'm sure there's a demand for that wheel modified to fit an earlier column. I'm sure it's a few hundred dollar wheel as it sits. I'd start keeping an eye out for a horn ring. The limeworks reproduction horn ring is for the earlier crestliner wheel, so this will be a tough one to find.
Automotive Stud is offline   Reply With Quote
Old 11-14-2020, 08:41 PM   #12
Ardun
Ardun's Avatar
These are the people: https://www.kochssteeringwheels.com/
Old 11-14-2020, 08:46 PM   #13
Ardun
Ardun's Avatar
I have $1200 in my wheel including recasting, repairing and Chroming the horn ring. Most horn rings do not come with the horn blowing mechanism and one has to be careful when buying one. Also, the correct color horn button can be an issue as well as it’s quality. Yours looks very nice.
Old 11-14-2020, 08:47 PM   #14
Ardun
Ardun's Avatar
Old 11-21-2020, 08:37 AM   #15
hop up
hop up's Avatar
I recommend steering wheel Kris and his work is amazing but I enjoy doing it myself
File Type: jpg 47D70972-297F-425B-85DE-E29360ADC13C.jpg (86.7 KB, 18 views)
