04-02-2020, 10:59 AM | #21 |
Re: U-joint Play (again!)
Thanks everyone for your comments. I reckon I'll be getting a NOS u-joint. Since I've included pics and measurements of what "bad" looks like, I plan to include pics and measurements of what "good" looks like once I have it....
04-02-2020, 11:02 AM | #22 |
04-02-2020, 11:13 AM | #23 | |
Prior to retirement, I made numerous dies that produced these Belleville's in about as many sizes and pressure as a guy could imagine. That repop washer depicted in your post does not appear to be correct. Will it function properly? Me? I wouldn't chance it. Plus, it's obvious it has never been heat treated so how exactly is it to have a memory? I just don't envision that one working as Ford designed.
"I can explain it for you. However, I can't understand it for you". Last edited by Kube; 04-02-2020 at 11:18 AM. Reason: added information |
04-02-2020, 11:16 AM | #24 | |
04-02-2020, 11:16 AM | #25 |
There's a lot more that goes in to manufacturing a Belleville spring than the "cup". There are designed load specifications at specific heights of deflection, hardness ratings, etc.
04-02-2020, 11:22 AM | #26 | |
You are welcome to doubt this particular part. In fact I suggest you install it in your car.
04-02-2020, 11:44 AM | #27 |
Anyone care to tackle my "How to tell if a U joint is good" question? Thanks. JIM
04-02-2020, 11:46 AM | #28 | |
I apologize for my typo. I knew it was Roy. I lost my good friend this morning over the virus. I'm not in a good place emotionally right now I'm going to step away for a bit. If you last comment was a snarky response, I totally don't appreciate it. If I'm reading more into your intended tone, then I apologize in advance. Thanks, Tim |
04-02-2020, 12:08 PM | #29 |
Sorry to hear that Tim. Awful things are happening right now.
In response to 19Fordy. If you take the joint and try and rotate the two ends relative to each other and can feel negligible play, while still having an ability to slide freely sideways on both sides of the cross piece, then (I would say) the joint is serviceable. Any rotational play or looseness between the bushings and the yokes means keep looking. Mart. |
04-02-2020, 05:41 PM | #30 |
just thought why not fit a spacer behind the yoke this is the way eaton keep their yokes tight. [ works just about every heavy truck trans uses this method]
04-02-2020, 06:28 PM | #31 | |
04-14-2020, 02:33 PM | #32 | |
So, this solves my u-joint play problem. As for why Drake makes/sells units that are so short, I'll let someone else figure that out. |
04-14-2020, 05:35 PM | #33 | |
I'd venture a guess that "Bob's boys" have likely "never heard of that problem before". |
04-14-2020, 06:25 PM | #34 |
Now that's the way it's supposed to look!
10-22-2021, 12:08 PM | #35 |
Buford40: Here's a helpful thread.
https://www.fordbarn.com/forum/showt...sal+joint+bolt |
