Old 07-31-2021, 07:16 AM   #1
Oberfranke
Oberfranke's Avatar
Default Size square on banjo
What size is the square on the Banjo (Differential Housing)? (Metric sizes are standard for us)
Thanks in advance
Oberfranke is offline   Reply With Quote
Old 07-31-2021, 07:46 AM   #2
Russell Reay
Default Re: Size square on banjo
Bigger than 3/8", smaller than 1/2", probably 11 or 12 mm. The book says to use a 3/8 drive ratchet. It is pretty sloppy, but a 1/2" drive is too big.
Russell Reay is offline   Reply With Quote
Old 07-31-2021, 12:30 PM   #3
katy
katy's Avatar
Something like this:
https://www.carid.com/k-tool-interna...eid=3058478643
Old 07-31-2021, 07:57 PM   #4
Chuck Sea/Tac
Chuck Sea/Tac's Avatar
You may have to grind down from the size to big.
Old 07-31-2021, 08:29 PM   #5
Tom Endy
Tom Endy's Avatar
The 3\8" breaker bar will usually lock in place and a tap with a hammer will loosen it. Most have been butchered up by people using channel locks or vice grips to loosen them. The suppliers sell a replacement that is actually 3\8" and the breaker bar and socket wrench fit correctly.
Tom Endy
Old 07-31-2021, 08:30 PM   #6
Tom Wesenberg
Tom Wesenberg's Avatar
7/16", and if you find a 7/16" square head bolt, that and a Vice Grip usually work well.
Old 07-31-2021, 08:37 PM   #7
dave in australia
I bought a cheap brand 1/2" drive extension and ground down the end to 7/16" square. Fits in and I can use a 1/2" ratchet to loosen and tighten the plug. Was a $5 solution.
dave in australia is offline   Reply With Quote
Old 07-31-2021, 08:54 PM   #8
mleder
Buy a piece of 7/16" key stock from a bearing supplier or industrial supplier like Graingers or McMaster Carr. Cut it into sections use one and give the rest to your buddies. Its cheap
mleder is offline   Reply With Quote
Old 07-31-2021, 09:00 PM   #9
McMimmcs
McMimmcs's Avatar
A very intelligent solution. Smart thinking on your part !
Old 08-01-2021, 06:59 AM   #10
Kurt in NJ
Kurt in NJ's Avatar
I use the tool that came in the tool kit--- the tail end of the adjustable wrench
Old 08-01-2021, 08:39 AM   #11
Patrick L.
Patrick L.'s Avatar
Yep, just an old 'shorty' extension. Ground it down to size and been using it for 50 years.
Old 08-01-2021, 09:39 AM   #12
Ray in La Mesa
I had a VW lug stud laying around so ground it to fit the square.
Ray in La Mesa is offline   Reply With Quote
Old 08-01-2021, 02:49 PM   #13
Ivan in southeast va.
Ivan in southeast va.'s Avatar
I have been using a spare 3/8" for years.
Ivan in southeast va. is offline   Reply With Quote
