03-19-2011, 11:53 AM | #1 |
Technical Axle length
Does anyone out there know if the lengh of the 37-41 Axle is the same as the 46-48. If not what the differences are. Thanks for the help. Tom
03-19-2011, 12:12 PM | #2 |
Re: Technical Axle length
The difference is the overall length, they are not even remotely interchangable... Unless you use the matching axle tube with it... They are about 3/4"- 1" or so apart... Karl
03-19-2011, 12:14 PM | #3 |
They are different, I think the 46 is over 33", the 35-41 under 33, the "green book" has all the differences, the 35-36 are same length as 37-41 but more teeth on gear --as a pair with matching gears can interchange with 37-41
03-19-2011, 12:14 PM | #4 |
Thanks Karl ! Tom
03-19-2011, 12:15 PM | #5 |
