Old 05-06-2017, 06:42 PM   #1
firerod
Default Lyon wheel covers
Does anyone have an original 16" Lyon wheel cover they could take a picture of how they mount.
firerod is offline   Reply With Quote
Old 05-07-2017, 10:03 AM   #2
deuce5wndw
deuce5wndw's Avatar
Default Re: Lyon wheel covers
Not sure this is a Lyon brand covers
deuce5wndw is offline   Reply With Quote
Old 05-07-2017, 06:23 PM   #3
firerod
Any idea how that attaches to the wheel? I bought a set of Lyon re-pops from Kevin Lee on the HAMB which are a very nice set of wheel covers but the have no way to attach other than running a trim ring. I would like to use them without trim rings and am looking for ideas.
Old 05-07-2017, 06:46 PM   #4
34coupe
34coupe's Avatar
the caps are made to fit 16" wire wheels or 16 " kelsey hays wires, I thought Kevins caps were held on by the hub cap, Dave
Wanted: 1933-34 Ford roadster project-parts anything roadster Now go out in the garage and build something !
34coupe is offline   Reply With Quote
Old 05-07-2017, 07:53 PM   #5
Tony, NY
If you're talking about the spun caps, guys use 4 screws behind the center cap or sheet metal screws around the outer lip into the wheel. Read thru this thread. https://www.jalopyjournal.com/forum/....782916/page-3
Tony, NY is offline   Reply With Quote
Old 05-08-2017, 07:43 AM   #6
Don Rogers
Don Rogers's Avatar
Firerod, The original wheel covers snap on and are held in place by the tabs. As you can see by the photos, the original covers had a stainless band around the outer circumference , with a rubber seal beneath it. I have also included the mounting instructions included in the brochure.
Don Rogers is offline   Reply With Quote
Old 05-08-2017, 08:52 AM   #7
deuce5wndw
deuce5wndw's Avatar
Don, it never ceases to amaze me the information you come up with! Whether Lyon caps or lock codes you have always helped me out! Thank you very much, Dale.
Old 05-08-2017, 09:16 AM   #8
firerod
Thank you all for the pictures and info. Don that is awesome you have the original instructions, wow! I will have to see if I can fab some tabs to mount like the originals.
Old 05-08-2017, 10:48 AM   #9
Don Rogers
Don Rogers's Avatar
You are both welcome. If I hadn't scanned this into the computer years ago, I would never be able to find it.
