12-09-2018, 03:06 AM | #1 |
Brake T Bolt
Is this the correct 91A-2150 front brake T bolt on the 39-48 passenger cars? It only has one outlet hole other than the inverted end that looks to screw into a hose. I've seen the reproduction bolts with that part number and they have two outlet holes on the side.
12-09-2018, 08:07 AM | #2 |
Re: Brake T Bolt
Not sure but may go on passenger side where it dead ends at front wheel .
12-09-2018, 08:17 AM | #3 |
Re: Brake T Bolt
Either one or two holes will work on the banjo bolt.
If it will make you feel better just drill the hole thru the other side.
12-09-2018, 08:21 AM | #4 |
Re: Brake T Bolt
12-09-2018, 09:33 AM | #5 |
Re: Brake T Bolt
The banjo bolt on my '46 only had one hole, and there is no banjo bolt used on the passengers side. The brake hose on the passengers side clips in to a bracket on the frame, and the fitting on the steel line from the drivers side threads in to the end of the brake hose.
12-09-2018, 09:36 AM | #6 |
Re: Brake T Bolt
12-09-2018, 03:18 PM | #7 |
Re: Brake T Bolt
Thanks for the replies, I'm putting hydraulic brakes on a Model A and ran the lines like the '39-'48 cars. I guess I was over thinking it, I figured it needed two holes in the banjo bolt to move fluid to the passenger line. Since the bolt shoulder drops off where the hole is drilled and each side of the brass block has copper crush washers I guess the fluid just moves around the bolt and fills all the space where it needs to go.
12-11-2018, 09:38 PM | #8 |
Re: Brake T Bolt
I've had some problems with the new copper brake washers leaking that are being sold. They are just flat smooth sided copper washers. The originals have the nice ridges in them that make the seal. I would reuse an old one with ridges before I would use a smooth one. I'm sure the correct ones are out there for sale somewhere?
12-12-2018, 02:09 AM | #9 | |
Re: Brake T Bolt
12-12-2018, 02:49 AM | #10 | |
Re: Brake T Bolt
Bryn, If you do have a copper washer there you will get a better seal if the washer is annealed, before its fitted. heated up to a red heat then quenched in water. This will do the trick for seaing. Phil NZ |
12-13-2018, 02:00 AM | #11 |
Re: Brake T Bolt
