08-10-2011, 11:01 PM | #1 |
Speedo not working-cable or Speedo unit?
Last week the speedometer started making a "clink-clink-clink"sound then stopped working. I ordered a new cable,and installed it. I noticed the speedo input turned a little hard so I lubed it with a little lock oil. The cable was broken down near the drive gear. When everything was back together,it still did not work. Is my speed head broken inside? Its a Stewart Warner oval head,that shows 66K,and the lead seal is still in place.
If you think SBC's are "Old School" you are not old enough. |
08-11-2011, 12:13 AM | #2 |
Re: Speedo not working-cable or Speedo unit?
Remove the cable from the speedometer and see if the speedo turns easily. My bet is that it needs to be freed up and lubed.
08-11-2011, 06:02 AM | #3 |
I would also check the speedo drive unit on the drive shaft. It's an easy job to take it off and have a look. When I needed one for my car I found a couple that were stuck.
08-11-2011, 12:20 PM | #4 |
keep your old speedo cable, cut it down so you can put it in a drill and test the speedometer. Drill goes in reverse.
08-11-2011, 12:22 PM | #5 |
08-11-2011, 01:31 PM | #6 |
Peteva |
08-11-2011, 01:38 PM | #7 |
In my first post,I said I lubricated the speedo head. It was turning fairly hard,and freed up some with the oil. It does not move off of zero. A drive gear can't break the cable.I am wondering if something broke inside.I don't know what they look like inside. I think this is the original untouched speedo,still has the lead seal.
Thread Tools | |
Display Modes | |
