03-18-2017, 05:10 PM | #1 |
What Next? Air-Halk (Emergency Model A Tire Pump)
Some may have seen this ad on TV before; but just saw it.
Two payments of $29.95; battery operated and looks like a battery operated hand drill. Produces compressed air to inflate tires & other inflatable items. Either call 1-800-667-4142 now; wait until the price go down, and/or continue using your hand pump and/or whatever. |
03-18-2017, 05:31 PM | #2 |
Re: What Next? Air-Halk (Emergency Model A Tire Pump)
I'll stick with my Schrader "Spark Plug Tire Inflater" Just screw it into the spark plug hole of your choice and start the engine.
03-18-2017, 05:46 PM | #3 |
A few early non-Ford cars had an air compressor on the side of the engine powered by the camshaft ..... just flip a lever with engine running & inflate tires.
03-18-2017, 06:25 PM | #4 |
Look closely at those air gun offers.I have been looking at one called the Air Dragon.I started looking around and found the basic one comes with a cord for the cigarette lighter.The battery is an additional purchase.I have air bags in my Dodge trucks and want one for just those.When I load the trailer I like about 30-40 pounds of air in them.What I don't like is to run the trailer empty to pick something up with the bags aired up.I have an aluminum flatbed and the truck beats me badly when running empty with air in the bags.I thought one of those pistol inflators would work fine.The bags are very low volume.
03-18-2017, 07:40 PM | #5 |
I buy the cigarette lighter socket air compressors at swap meets for 5 to 10 dollars and keep one in each car. They work fine.
03-18-2017, 07:48 PM | #6 |
1929 Model AA - Need long splash aprons! |
03-19-2017, 07:28 AM | #7 |
Do any of the cigarette lighter compressors work on 6v? Thanks
03-19-2017, 10:26 AM | #8 |
I prefer the real compressor that Northern Hydraulics sells for about $80.00. Only works on 12 Volts, but will air up a tire in a couple of minutes. You have to connect it to the battery directly as draws too much current for the cigarette lighter. Don't have time to wait hours for the toy compressors to fill a tire.
03-19-2017, 10:33 AM | #9 |
Sears has a Lithium battery drill driver style air compressor I saw someone use at a Model A meet once. Not inexpensive, but a possibility.
03-19-2017, 11:34 AM | #10 |
As you can see many different options. I also like the Air Hawk. Easy to carry in your Model A. If we are older then easy on our body. Also great to inflate balls etc. The Air Hawk plus has the carrying case, battery charging cord and lighter adapter. Worth the money you pay. I am purchasing one for my son's.
Henry' s 31 |
03-19-2017, 12:10 PM | #11 |
06-23-2017, 06:25 PM | #12 |
I have a old antique compressor that was manually driven by the motor but don't know how it was hooked up .It is about the size of a pop can .I have a Model A tire pump but it needs a hose .??
06-23-2017, 06:31 PM | #13 |
Do you have a picture of the compressor you have? Or,a description? I've seen some different versions of these,always curious about them.I have one that hangs on the side of the motor on a hinge,and to use it you swing it in to ride on the back of the fan belt.
06-23-2017, 07:01 PM | #14 | |
Weren't they used on tractors and piped to the planter (seeder) being pulled? |
06-23-2017, 08:07 PM | #15 |
MAGIC Pumper Uppers are a LOT OF HOT AIR, to make Quick BIG BUCKS. Next week will be ELECTRIC Hair Brushes to SCALE your FISH quickly.
Bill W.
06-23-2017, 08:25 PM | #16 |
The Air Hawk works very well. I got it cheaper on Dailydeals.com. I purchased the air Hawk pro an it comes with the rechargeable battery and also a carrying case. I have several fender mounted spare Model A's and most of us have to let some air out to place it in the fender well. When not using the Model A you can place it in your modern car. Several members of our Model A Club have one.
Henry' s 31 |
06-23-2017, 08:25 PM | #17 |
I have found the perfect pump.
It will work on 6 or 12 volt cars, + or - ground. Never needs charging or battery's, is always ready to use. Is simple to operate. |
06-24-2017, 07:36 AM | #18 |
Hey 30 Coupe! I've got one like that.
06-24-2017, 08:26 AM | #19 |
I carry a 12 volt plug in cigarette lighter pump in my modern car. One day I parked my 1929 Model A beside the modern car to inflates the Model A tires. Guess what? I could not fasten it to the metal stem valve as the flip connector to the valve required more space than the metal stem allowed between tube valve and center area of the wheel.. Good news it worked OK on my 1930 with metal stem valve as there was enough space so that the I inflated the 19" tires with no problem.
06-24-2017, 08:56 AM | #20 |
$20 Ryobi battery operated compressor at Home Depot is the way to go.
http://www.homedepot.com/p/Ryobi-18-...P737/206159256 |
