11-07-2010, 12:30 PM | #1 |
40 battery tray
Hey guys, trying to figure out battery tray location. The first pic I am posting has what I believe to be a 40 at a car show with the correct battery tray location. I set mine up there as you can see but came across a problem in the rear mounting hole. What am I doing wrong?? Thanks
11-07-2010, 01:56 PM | #2 |
Re: 40 battery tray
It looks like if you flatten out the tab and reform it it would work, maybe. It could be also the wrong tray. Good luck
1939 Fordor Deluxe 1939 Ford Coupe Std 1940 Ford pickup Nothing in life is to be feared; it is only to be understood. |
11-07-2010, 02:02 PM | #3 |
Re: 40 battery tray
[QUOTE=40fordpu;108424]Hey guys, trying to figure out battery tray location. The first pic I am posting has what I believe to be a 40 at a car show with the correct battery tray location. I set mine up there as you can see but came across a problem in the rear mounting hole. What am I doing wrong?? Looks to me like you got it right, but why is that battery box bolt tab "bent" in such an awkward manner? I tried to take photos of that particular tab and how it bolts to the frame but wasn't able to take the photo. I believe that particular tab is held in place and hidden by the same bolt that holds the inner fender panel. You can see the silver colored nut up inside my frame in the second photo that secures it.You may have the wrong tray as your bolt tab looks different than the one I bought in a Drake catalog from long ago in the 80's (shown)? Mine fit all 3 try bolt holes in the frame - 2 on top, 1 on the side. You could modify the tab without too much work.
11-07-2010, 02:05 PM | #4 |
Re: 40 battery tray
If you flatten out the tab, and rotate the tray slightly, does it align with the hole in the top of the frame?
I'm pretty sure my tray only fits to holes on top of the frame, but it may have been modified..?? Mart. Edit - Can see the other pics now - looks like mine is wrong. If you flatten out the tab and rebend it, it looks like it will align with the hole in the side of the frame. |
11-07-2010, 11:28 PM | #5 |
Re: 40 battery tray
All holes line up but the one with the bent tab. I am confused.
11-08-2010, 01:12 AM | #6 |
Re: 40 battery tray
11-09-2010, 04:59 PM | #7 |
Re: 40 battery tray
It looks exactly like the repo I got several years ago from one of the mod A parts suppliers. It was just made wrong and they confirmed it and gave back my money. Looks like you got one that was never returned. Suggest you look for another one that is made right.
Peteva |
11-12-2010, 07:54 PM | #8 |
Re: 40 battery tray
***UPDATE*** My brother and I took a hammer and some forming tools and bent the piece back. Worked really well and all the holes line up. Thanks guys
Thread Tools | |
Display Modes | |
