Old 06-20-2013, 10:13 AM   #1
FRITZ47
FRITZ47's Avatar
Default '40 Ford Trunk Cardboard Question
We are finishing our 1940 Ford and bought an upholstery kit from LeBaron Bonney, which had new black trunk cardboard. My trim shop installer (Jan Roll of New Philadelphia) just called and asked if the cardboard that is in the rear of the trunk is attached to the back of the back seat, or attached from inside the trunk?
Could use some help on this.
Thanks, Fritz
FRITZ47 is offline   Reply With Quote
Old 06-20-2013, 11:02 AM   #2
Kube
Kube's Avatar
Default Re: '40 Ford Trunk Cardboard Question
Be certain the cardboard has a pebble grain finish. The smooth stuff is incorrect.
Old 06-21-2013, 09:48 PM   #3
Peteva
You can get a roll of material embossed with the correct grain pattern. This is to be glued on to your cardboard panels. Looks good when you are done. I got mine from Roy Nacewicz several years ago.
Peteva
Peteva is offline   Reply With Quote
Old 06-24-2013, 08:17 PM   #4
FRITZ47
FRITZ47's Avatar
This just came in from LeBaron Bonney - for my 1940 Ford Convertible. They sure are helpful at LeBaron Bonney (thanks Doug)
Fritz
Thread Tools
Display Modes
