Old 07-10-2014, 07:21 PM   #1
Bruce in southern OH
Bruce in southern OH's Avatar
Default How to change out steering Column support
Is it possible to remove and install this new steering column support on this early gas tank, information appreciated, thanks Bruce
Existing on left, unbroken on right
Close up of four rivets and possible solder on existing original part?
Bruce in southern OH is offline   Reply With Quote
Old 07-10-2014, 07:41 PM   #2
Bill Underwood
Default Re: How to change out steering Column support
Well I've cut them open on the top before and repaired rust
I would speculate that could be replaced with the tank opened up and the soldered up
Well from the inside as well
Lot of work as good tanks can still be found
Bill Underwood is offline   Reply With Quote
Old 07-10-2014, 07:42 PM   #3
Rowdy
I considered trying at one point and even had a plan of attack. It wouldn't have had rivets when done, just screws. If no one else has an idea short of cutting the tank open I will elaborated more. Rod
Rowdy is offline   Reply With Quote
Old 07-10-2014, 07:57 PM   #4
Bob C
If it's not going to be a fine points car how about using a late 31 bracket.
Bob
Old 07-10-2014, 09:48 PM   #5
Mike V. Florida
Mike V. Florida's Avatar
Bob
https://fordbarn.com/forum/showpost.p...03&postcount=8
Old 07-10-2014, 11:30 PM   #6
Russ/40
Russ/40's Avatar
Rowdy, please elaborate.....
Old 07-11-2014, 12:16 AM   #7
Ed Wendell
Ed Wendell's Avatar
Bruce,
Get your tank dipped and cleaned so you can use a torch on it.
Grind off the old rivets, then take a torch and un solder the old bracket.
Clean and do a GOOD job of tinning the tank and replacement bracket.
Locate some explosive brass rivets.
After you rivet the bracket in place, solder the bracket
Ed
Ed Wendell is offline   Reply With Quote
Old 07-11-2014, 01:36 AM   #8
Mike V. Florida
- Explosive rivets:
These are used, if the components are accessible only from one side (light metal construction, aircraft manufacture). The explosive charge is electrically ignited thus widening the rivet shank.
One source
Old 07-11-2014, 06:42 AM   #9
Thanks for all the info, will start on bracket,
Old 07-11-2014, 09:29 AM   #10
1931 flamingo
1931 flamingo's Avatar
Why not go to the later column support that attaches to the dash??
Paul in CT
Old 07-11-2014, 11:38 AM   #11
Russ/40
Russ/40's Avatar
Originally Posted by Mike V. Florida View Post
- Explosive rivets:
One source
Mike, I went to the site, but little info there as to rivet details or minimum order. Have you explored any of this? Light construction specification may not be adequate for such a load bearing component, as I don't think solder is where the strength is coming from. I think the solder is for sealing. Comment??
Also, when people say solder, are they talking lead tin alloys, or silver alloys? I imagine it is difficult to silver solder a previously lead soldered component.
Rowdy, still waiting for your solution???
Old 07-11-2014, 02:24 PM   #12
Mike V. Florida
I have no personal experience with the explosive rivets. You are 100% right about the solder being used for just sealing.
If this is for a show car and it were mine, I would look for another tank or open it then clean it and replace the part. If not for show I would put in a '31 mount.
Old 07-11-2014, 02:45 PM   #13
ford3
forget about changing the bracket, put the later style one on that attaches to the dash, if you don't you will still have the problem of the steering column pulling on the bracket on the bottom of the tank and causing it to start to leak again, not a good thing having gasoline dripping on your foot while driving, all most like a ww2 jap zero , they were called type 2 torches because they lite real easy, that's not what you want
ford3 is offline   Reply With Quote
Old 07-11-2014, 09:56 PM   #14
Red Ryder
Recently welded same.
Red Ryder is offline   Reply With Quote
Old 07-11-2014, 10:22 PM   #15
Fred K-OR
Fred K-OR's Avatar
I put the later bracket on both of my rigs. You can find them on EBay all the time or check with Bert's in Denver-I would think they have them. Also you can buy them new from some of the vendors.
I guess my question is kind of the same as one of the posts above. If the bracket shows that much rust, what do you have inside the tank?
The job is not hard to do. You just have to drill one hole in the windshield area. If you would like some pictures, send me a email and I will get you some.
Fred Kroon
1929 Std Coupe
1929 Huckster
Fred K-OR is offline   Reply With Quote
Old 07-12-2014, 11:43 AM   #16
olebmw
If you decide to change out the bracket please post the details. I've been thinking about doing the same repair. I would use silver solder. Dan
olebmw is offline   Reply With Quote
