10-25-2013, 06:47 PM | #1 |
Adjustment Wedge Removal
I have a 36 PU with mechanical brakes.
How do you remove the brake adjustment wedge from the backing plate? Do you remove the cap from the opposite side? How is this cap removed? It appears that the housing is swedge a little over the cap along with staking. Thanks, Norm |
10-25-2013, 08:35 PM | #2 |
Re: Adjustment Wedge Removal
Norm, The adjuster cranks in from the backside, and pushes the dustcap off on the inside. Sounds like you're about to install floaters? The dustcap can remain off, but you'll need to cap off the backside where the adjuster was. The best way to do this is to cut the adjuster off using a cutting wheel. Screw it back in from the back, and use a dab of thread seal to hold it in place till the next time you need to adjust your brakes.
Alan |
10-25-2013, 10:49 PM | #3 |
