Old 04-22-2020, 05:08 AM   #1
kooloval
kooloval's Avatar
Default 1938 std coupe hood adjustment
I want to raise the hinge end by about 4mm to line up the side trim but the hinge is on a vertical part of the bulkhead & the holes not slotted. Any ideas?
kooloval is offline   Reply With Quote
Old 04-22-2020, 09:01 PM   #2
bill3337
bill3337's Avatar
Default Re: 1938 std coupe hood adjustment
If '38 hood hinges are the same as '37, you may have to slot the holes slightly, specially if they are aftermarket hinges. You need to be able to sort of "rock/rotate" the hinge body slightly. The hinges for '38 appear to be slightly different on the pictures I can see, but the principle is likely the same.
bill3337 is offline   Reply With Quote
Old 04-22-2020, 11:26 PM   #3
swoopNZ
MEMBER EMERITUS
1/4" is the correct size bolts for the front 2.
This may help.
A lot of folk use 5/16" bolts which gives little room for up and down adjustment.
swoopNZ is offline   Reply With Quote
Old 04-23-2020, 02:52 PM   #4
TJ
TJ's Avatar
Are you sure the holes in the cowl are not slotted?
