Old 02-24-2019, 07:44 PM   #1
bill3337
bill3337's Avatar
Default '37 trunk hinge question
Can someone tell me what was used in these metal cups that go over the trunk hinge bolts inside the car. When I removed them originally, they seemed to be full of something like old plumber's putty. Was that to keep water from leaking into the trunk? What's the proper material to use on these? I'm thinking of using plumbers putty again....... Thanks, Bill Campbell
bill3337 is offline   Reply With Quote
Old 02-24-2019, 08:08 PM   #2
TJ
TJ's Avatar
Default Re: '37 trunk hinge question
You could use the plumber's putty , but a better choice would be the soft black automotive strip type sealer.
Old 02-24-2019, 08:10 PM   #3
bill3337
bill3337's Avatar
I'm not familiar with that. Do you have a brand? Is it like tape or what?
Old 02-24-2019, 08:11 PM   #4
bill3337
bill3337's Avatar
Ok, I see Napa has something like that, if that's what you mean. I'll try them.
Old 02-24-2019, 08:55 PM   #5
paul2748
paul2748's Avatar
Maybe 3M strip caulk - # 08578
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 02-25-2019, 09:31 AM   #6
TJ
TJ's Avatar
This would be the same stuff I initially recommended. Can be found at some auto parts stores or your local automotive paint dealer. thanks for the part # Paul
