Old 11-20-2020, 05:10 PM   #1
jimTN
Default rear axle gear ratio chart
Sometime in the past someone posted a chart that had rear axle ratios, tire sizes, rpms and road speed data. It included everything from Model A 19" rubber on up thru 15" stuff. I printed it off but its deep somewhere in my piles of paper. If you have such a animal, could you please post it. A friend has a 60 running a 3:78 in a T with 19" A tires and wants to get a more optimal ratio that will put the RPM range around 2500-3000 rpm at 60 to 65 mph.
jimTN is offline   Reply With Quote
Old 11-20-2020, 05:43 PM   #2
JSeery
JSeery's Avatar
Default Re: rear axle gear ratio chart
It is an easy formula, just calculate it for your parameters.
Old 11-20-2020, 06:02 PM   #3
Hotrodfil
Hotrodfil's Avatar
Here's a link to mine on google drive.
You can edit it online, or download it as an excel file. Works in Libre office too.
https://docs.google.com/spreadsheets...gid=1208129397
Hotrodfil is offline   Reply With Quote
Old 11-20-2020, 06:54 PM   #4
HDowse
HDowse's Avatar
Here’s the one I use:
http://www.advanced-ev.com/Calculators/TireSize/
HDowse is offline   Reply With Quote
Old 11-20-2020, 07:37 PM   #5
V8COOPMAN
V8COOPMAN's Avatar
This has got to be the one.....yes, no? DD
Click Links Below __
T5 W/TORQUE TUBE
Old 11-21-2020, 08:27 AM   #6
jimTN
Thanks to all, the formulas above will work for what I need. That speedometer chart is great but not the chart I am looking for.
Old 11-21-2020, 09:17 AM   #7
JSeery
JSeery's Avatar
There are a lot of calculators online, but I have seen several of them product incorrect results! I would at least check them against doing it by hand at least once to double check the fill in the blank calculators. It is a very simple formula:
RPM = (MPH X Axle Ratio X 336) / Tire Dia
As an example
60 MPH
3.78 Axle Ratio
30 inch Tires
RPM = (60MPH X 3.78 AR X 336) / 30 TD
RPM = (76,204.8) / 30
RPM = 2,540
Old 11-21-2020, 11:22 AM   #8
flathead 39
flathead 39's Avatar
Originally Posted by HDowse View Post
Thanks, this is eactly what I need to decide whether to change my 3.78 to 3.55 or 3.25.
flathead 39 is offline   Reply With Quote
