Old 08-02-2020, 01:24 PM   #1
louieglen
Default alternator
I bought a model A the fellow said he had just put a new 6V alternator on. I got it home noticed it wasn't charging Checking it has a 12V battery neg ground. How much trouble am I in? What alternator do I need to get that will fit the A? Thanks in advance.
louieglen is offline   Reply With Quote
Old 08-02-2020, 01:28 PM   #2
wmws
Default Re: alternator
Have you had trouble with the battery discharging.
wmws is offline   Reply With Quote
Old 08-02-2020, 01:36 PM   #3
louieglen
Yes.
Old 08-02-2020, 01:44 PM   #4
wmws
Have you checked the output of the alternator with a multimeter. If so what did you get for output. If the output is good you may just have a bad battery not taking a charge. If your not getting any output then maybe you have a bad diode or some other trouble in the alternator. I will let others recommend and alternator as I don't use them.
Old 08-02-2020, 02:07 PM   #5
wmws
I just noticed that you have a 6 volt alternator and a 12 volt battery. That won't work.
Go all 6 volt or 12 volt. I would check the output of the 6 volt alternator and if it is good just put in a 6 volt battery.
Old 08-02-2020, 02:25 PM   #6
Charlie Stephens
What do you mean when you say "Checking it has a 12V battery neg ground". What is "it"? Is the vehicle 12 volts negative ground? Is the alternator 12 volts negative ground? If "it" is the alternator did you check it out or just read the tag? If you just read the tag may have been left over from before the alternator was modified the alternator to 6 volts.
Charlie Stephens
Old 08-02-2020, 02:45 PM   #7
louieglen
I don't understand your question. The car has a 6V alternator, and a 12V battery the neg. post is grounded to the car.
Old 08-02-2020, 02:51 PM   #8
louieglen
I don'T want to change the 12V battery with a 6V. if I did that I would have to redo the head light's they are sealed beam. I would rather change the alternators. I need to know what 12V alternator single wire neg ground to buy that will fit the car.
Old 08-02-2020, 05:31 PM   #9
Mulletwagon
Mulletwagon's Avatar
All Model A parts dealers offer 12v alternators that are bolt on. Just an example:
https://www.snydersantiqueauto.com/P...el-a/generator
IMHO, negative ground 12v is the way to go.
Mulletwagon is offline   Reply With Quote
Old 08-02-2020, 07:18 PM   #10
duke36
Wagner Products: reliable and good pricing, 6v and 12v.
duke36 is offline   Reply With Quote
Old 08-03-2020, 07:52 AM   #11
larrys40
Duke,
Yes tom Wagner has without question the best alternator and bracket out there.
Tom is part of our st Louis Model A club and is not only a great knowledgeable guy on auto electrics but has the best alternator. I use them in customers cars all the time.
The other brands don’t hold a candle.
Look up Wagner products on line or he advertises in the Model A News and Restorer .
Larry shepard
larrys40 is offline   Reply With Quote
Old 08-03-2020, 09:13 AM   #12
Badpuppy
The 6 volt pos or neg ground alternator is a conversion of the original Delco 10Si 12V negative ground, which are common as nails these days and can be had pretty cheap. Even the Asian knockoffs work well; the tech isn't rocket science any more. They were used on most Chevy models, many small Fords, AMC Jeeps, and others back in the day. You should be able to do a direct swap. You could then sell the 6V and make a few $$.
Badpuppy is offline   Reply With Quote
Old 08-03-2020, 09:23 AM   #13
katy
katy's Avatar
Why not contact the PO and verify that it is a 6V alternator.
Old 08-03-2020, 04:53 PM   #14
Patrick L.
Patrick L.'s Avatar
We still don't know the output even after being asked.
Why would someone stick a 6v on a 12v vehicle. Maybe its missed marked.
