Old 04-08-2013, 11:15 AM   #21
Fred K-OR
Fred K-OR's Avatar
Default Re: New engine
"BTW
I have thisRadius-ball using the rubber-ball
I do not need springs anymore??
How strong to tighten nuts?
Ball still should be able to move inside ??"
Christoph, you may want to "rethink" the rubber ball idea. They say the rubber ball will wear out quickly and you will have a loose ball. But if you watch it over a period of time, it may work just fine. I converted mine back to not use the rubber ball. So don't know about the springs. Maybe someone else may have an answer on that.
Fred Kroon
1929 Std Coupe
1929 Huckster
Fred K-OR is offline   Reply With Quote
Old 04-08-2013, 01:24 PM   #22
Christoph
Christoph's Avatar
Terry
Your german is way than better than mine, i guess
Im grown old - I dont need distructions anymore
I turn arround and forgot what i was going to do
It happened some time ago ,that i forgot the crank after
doing adjustments... I found out 2 miles later when it went
with a big bang. New cranks from vendors are black (not
chrome anymore) and the paint goes together with
the sticker which says "Made in Korea".
ronn
I dont go onto Autobahn and feel great if i dont spot Polizei at all .
Fred
Long time no contact
Rubber ball is soaked with oil and ugly....
Dont like that at all
Will find out about - no need to rush things.
Found some more trouble today
Alu-fan was somewhat loose which caused noise....
Fan-belt was to short and tight.
Changed to a loose belt
I do long time tests how lose a fan belt can be
While working, i found myself changing the
pitman-arm (looked BAD) and
draglink...wow - who welded that draglink???
And i found nice 6v 32/32 bulps in my garage.
Why didnt i install earlier
Going on with this speed, car will be all new in about a year.
Christoph is offline   Reply With Quote
Old 04-08-2013, 02:31 PM   #23
Fred K-OR
Fred K-OR's Avatar
Christoph, yes it has been a long time since we "rapped" on this site. See your posts once in awhile. Looks like you have done well in making you rig "new" again. But it is fun!!????? Right?? Anyway, it gives us "older" guys something to do.
Fred Kroon
1929 Std Coupe
1929 Huckster
