Old 01-06-2021, 02:08 PM   #1
Don S
Default Lite rust inside block
I removed my top hose to get at the thermostat,because I was experiencing an over heat situation . I checked the thermostat on the stove in a large can of water. Used a laser reader to check when thermostat opened , 192 deg. Too high for a 160 degree thermostat,and for my general needs. I will replace the thermostat,but I noticed looking down the gooseneck that there is a light rusting that I would rather not have.My A is in winter storage . Is there a safe way of neutralizing the rust by filling up the block only ,letting it work for awhile then flushing, without having to start the engine ? What product is safe for this process ?
Thanks Don
Don S is offline   Reply With Quote
Old 01-07-2021, 03:29 PM   #2
Chuck Sea/Tac
Chuck Sea/Tac's Avatar
Default Re: Lite rust inside block
Thermocure
Old 01-07-2021, 05:35 PM   #3
Don S
No luck here,auto supply stores don't know about this product .
Thanks for the suggestion
Old 01-07-2021, 06:42 PM   #4
Synchro909
Synchro909's Avatar
Go online and look at Liquid Intelligence. They do a range of products but you will likely only be interested in their 239 Engine Cooling System Cleaning Kit. They say it comes with a money back guarantee so they must be confident it is good.
Old 01-07-2021, 07:00 PM   #5
eagle
eagle's Avatar
Are you running anti freeze or straight water or ????.
Old 01-07-2021, 08:07 PM   #6
Don S
Running distilled water with rust inhibitor. Only use anti freeze for winter starage
Old 01-07-2021, 08:19 PM   #7
Don S
Synchro , I checked it out on-line, looks interesting, but need those if locally available.
Thanks for your input
Old 01-07-2021, 09:34 PM   #8
Chris Haynes
Chris Haynes's Avatar
I have successfully cleaned and de-rusted my entire cooling system with RUST911.
1921 Runabout
1930 Tudor
Early 1930 AA
Old 01-08-2021, 12:14 AM   #9
CWPASADENA
CWPASADENA's Avatar
X2
Chris W.
CWPASADENA is offline   Reply With Quote
Old 01-08-2021, 06:15 AM   #10
updraught
updraught's Avatar
https://www.amazon.ca/Thermocure-Coo.../dp/B00R74I5UY
Free delivery.
updraught is offline   Reply With Quote
Old 01-08-2021, 06:05 PM   #11
Don S
I used a product called Kleen -Flo , mixed the container with water and filled the block. After about 1 hour I drained it and flushed with garden hose till clear. I repeated the process . Very little color in the second flushing . I will replace the anti-freeze until spring.
Thanks all for your suggestions
Old 01-08-2021, 09:42 PM   #12
eagle
eagle's Avatar
If there is just a bit of rust on the surface of the water jacket etc it isn't time for panic. Go to your local auto parts store, get a radiator flush kit and use it as directed. Then use a good quality anti-freeze with built in rust inhibitor. If the system is plugged up, that's a different story.
Old 01-09-2021, 08:22 AM   #13
1crosscut
1crosscut's Avatar
Your choice but now that you have the rust taken care of and refilled with a 50/50 mix of distilled water and antifreeze leave it in there.
Seems to me the rust inhibitor your using isn't up to snuff.
Dave / Lincoln Nebraska
1crosscut is online now   Reply With Quote
Old 01-09-2021, 01:49 PM   #14
Ernie Vitucci
Agree with 1crosscut...I simply use 50/50 antifreeze and it stays green from year to year and the engine runs cool. I do run the Vintage Precision Thermostat housing and the thermostat that they provide...very good system...Ernie in Arizona
Old 01-09-2021, 02:05 PM   #15
Don S
Ernie,and crosscut , I ordered a Vintage Precision thermostat and housing last week, never really liked the one in the hose , also makes the hose more difficult to instal. Should be good to go this spring.
Thanks all
Old 01-09-2021, 03:56 PM   #16
whirnot
whirnot's Avatar
Fill the cooling system with vinegar, let it sit for two weeks, or three. Flush and immediately fill with 50/50.
Inexpensive and works.
Bill Worden
1929 Roadster
1929 Briggs Town Sedan
1930 Closed Cab pickup
Smith Motor Compressor
1951 Ford F1
High Desert Model A's
whirnot is offline   Reply With Quote
