Old 09-25-2020, 09:11 AM   #1
Bob Bidonde
Bob Bidonde's Avatar
Default Sport Coupe Top - Need Help
Need help regarding installing the outer top cover on a 1931 Sport Coupe. It is time to trim away the excess material of the outer cover at the back 2 corners of the roof. I need help determining what the cutting looks like. Does anyone have a picture or a good description of the shape of the cutting?
Bob Bidonde
Old 09-25-2020, 11:46 AM   #2
Bob from Northport
Bob from Northport's Avatar
Default Re: Sport Coupe Top - Need Help
Look in volume 5 of the restorer technical books. It has the complete information on restoring a 30-31 Sport Coupe.
The cut for the top back side follows the profile of the wood. It is centered along the wood beam. Don't cut to far on the sides. The trim piece must cover the cut. Just a little at a time and check with the length of the trim piece. I have photos some where but I will have to find them.
Bob from Northport
Northport, Michigan
Bob from Northport is offline   Reply With Quote
Old 09-25-2020, 04:41 PM   #3
rotorwrench
rotorwrench's Avatar
I can see that rear bow outline. Are the card boards in there? The card boards cover that stuff on the sides and help pad and make that all level out some. The rear valance will cover things up quite a bit there but it seems like there is a lot of material there like it's not quite padded out enough. It's hard for me to tell with limited photos.
Old 09-25-2020, 06:03 PM   #4
Bob from Northport
A few photos of one we did in my shop
Bob from Northport
Northport, Michigan
Old 09-25-2020, 06:07 PM   #5
Bob from Northport
Try this again Sorry. Cant get photos to download. Send me a PM/email and I will send photos
Bob from Northport
Northport, Michigan
Old 09-25-2020, 07:27 PM   #6
larrys40
Bob
They are a difficult top , but the key is patience and analyze all you are doing BEFORE you make any cuts. The key is pulling the material tight to pull any buckled areas smooth .
I have a 30 in the shop right now I can send you photos on if need be.
True the valance will cover your seams along the rear bow, but it’s still critical. Making the cut in the top is a judgement call as you go. Lebaron Bonney use to say it was the most difficult top they supplied to install . I think a cabriolet may be harder. Will find out this winter when I do my own 68c.
Make sure things are tight and tacked super well on the lower belt rail.
Larry
larrys40 is offline   Reply With Quote
Old 09-26-2020, 07:35 AM   #7
Bob Bidonde
Bob From Northport,
I sent you a message.
Larrys40,
Please send me pictures. Thanks for sharing.
My email [email protected]
Bob Bidonde
Old 09-27-2020, 09:01 AM   #8
Bob Bidonde
Still looking for some guidance and photos to make the trim of the Sport Coupe's top at the rear corners.
Bob Bidonde
Old 09-26-2023, 08:25 PM   #9
pklarkin
pklarkin's Avatar
Hi all,
I'm doing a Business Coupe roof but I have the same question. If any pictures were shared, can you please send them my way too? My email is [email protected]. Thanks!
Pat
pklarkin is offline   Reply With Quote
