10-26-2016, 09:09 PM | #1 |
'40 Lincoln axle shaft
Anyone know if a Ford axle shaft can be used in a Lincoln rear end? 1940 Lincoln.
10-27-2016, 10:01 AM | #2 |
Re: '40 Lincoln axle shaft
Check the part number in a Lincoln Chassis Parts books, if a Ford number should be OK. Paul J.
10-27-2016, 10:56 AM | #3 |
My Hollander Interchange shows 39-41 Ford, 39-40 Lincoln Zephyr, and 39-41 Mercury.
Bob |
10-27-2016, 11:18 AM | #4 |
Yep, same lenth. Just make sure the number of teeth corresponds with the old one.
10-27-2016, 12:49 PM | #5 |
Thanks fellows, my Ford parts book lists 81A-4235 rear axle shaft overall length 32.85"-16 teeth in gear, 39-41 passenger car. Anyone have a Lincoln parts book they can look up the spec? Thanks, Ted
10-27-2016, 04:47 PM | #6 |
10-27-2016, 04:56 PM | #7 |
I know the prefix on the axle part numbers differ than Ford but they will interchange. I've got a pair of NOS Ford axles in my Zephyr and I've got the old axles here and can find no difference in them compared against a Ford axle.
10-27-2016, 05:14 PM | #8 |
I thought that might be the case. Thanks for confirming it Ken!
10-27-2016, 07:32 PM | #9 |
Ken, the 41-48 Lincoln axles are longer in length. Lincoln issued a new axle housing 16H4011 ...the shaft is about 1/2 inches longer. Also necessitated a change in the 41 fender skirts.The lower skirt edge was flattened to keep the wheel from rubbing the skirt.Did Ford change it's width also?
10-27-2016, 07:54 PM | #10 | |
