01-19-2016, 08:47 AM | #1 |
Engine weight
Hello just getting started on a restoration of my 1931 Model A coupe. I have it disassembled down to removing the engine. Can some one tell me what the engine and transmission weigh? I know I need to get some of the manuals, any suggestions as to which ones to purchase first? Thanks
01-19-2016, 10:09 AM | #2 |
Re: Engine weight
About 500 pounds.
01-19-2016, 10:39 AM | #3 |
Re: Engine weight
Les Andrews, The Model A Mechanic Handbook (maroon/red one). I found this to e essential and if I couls just purchase one this would be it..
01-19-2016, 01:55 PM | #4 |
Re: Engine weight
yea, its not too heavy, still need to buy or borrow an engine hoist is best but can be done with a come-a-long
1929 Model AA - Need long splash aprons! |
01-19-2016, 04:54 PM | #5 |
Re: Engine weight
Tom's 500 lbs sound close When I did my engine I use a small 1 ton hoist and it was fine. I found the spark plug type lifter in I think the 3rd hole (it was 4 years ago) made it easier to get the engine out and in . I know the idea of only the threads of a plug holding the engine may sound scary but it works well at least for me.
01-19-2016, 05:00 PM | #6 |
Re: Engine weight
01-19-2016, 06:43 PM | #7 |
Re: Engine weight
Taken from " Model "A' Miseries and Cures " , it states , Engine Weight : The weight of the Model "A" engine including the clutch and the transmission is 473 pounds . Dont know from personal experience though .
01-19-2016, 11:36 PM | #8 |
Re: Engine weight
"The Ford Model A" by George DeAngelis, et al., lists 475 lbs including clutch and transmission (Section 2, page 18 of 2nd Edition). "How to Restore Your Model A" Volume 7 (Shipping Data on page 125) lists the following net weights:
456 lbs for A-6000 engine 517 lbs for AA-6000 engine 350 lbs for A-6005 engine. Insofar as I (Skip) could determine, none of the above specify whether this is the dry or wet weight, but I suspect it's dry. Also, here are some weights extracted from various FordBarn posts (principally by Tom Wesenberg if I recall correctly): 473 lbs – engine, complete (w/clutch & transmission) 160 lbs – engine, short block (w/head studs & crank pulley) 25 lbs – cylinder head 19 lbs – flywheel housing 12 lbs – Pressure plate 63 lbs - flywheel 3 lbs – clutch disc 10 lbs – engine pan 3 lbs – dipper tray 3 lbs – valve cover 2 lbs – timing gear side cover 4 lbs – timing gear front cover 28 lbs - crankshaft 6-1/2 lbs – camshaft (w/nut) 1-1/2 lbs – piston (w/wristpin & rings) Any corrections/additions would be appreciated. __________________ Skip Keyser
01-20-2016, 11:19 AM | #9 | |
Re: Engine weight
01-20-2016, 11:24 AM | #10 |
Re: Engine weight
I use this handy little tool (designed & manufactured by Bill Stipe). It grabs two spark plug holes and gives you several places to hook on to for whatever balances best.
Alaskan A's Antique Auto Mushers of Alaska Model A Ford Club of America Model A Restorers Club Antique Automobile Club of America Mullins Owner's Club Last edited by CarlG; 01-20-2016 at 11:29 AM. |
01-20-2016, 02:50 PM | #11 |
Re: Engine weight
A rule of "thumb": IF your hoist could lift a 500 Lb. Lady, then you're good to go.
Bill W.
01-20-2016, 02:59 PM | #12 |
Re: Engine weight
01-21-2016, 02:42 AM | #13 |
Re: Engine weight
I suggest not installing the forward motor mount until the engine is in the bay. I tried doing with the mount installed thinking it would drop in. It didn't. I removed the mount and she slid in perfectly. "My two cents"
01-21-2016, 10:58 AM | #14 | |
Re: Engine weight
Bill W.
01-21-2016, 12:28 PM | #15 |
Re: Engine weight
The first picture below shows what I use to lift engines. I feel using 2 spark plug holes is a little safer, even though 1 is probably OK. I used 2 dinged up "take a part spark plug bases" to insert carriages bolt though. The setup works well with a one ton lift like in the second picture.
Rusty Nelson |
01-23-2016, 09:14 AM | #16 |
Re: Engine weight
My thanks to all that responded. I have everything ready will take it out very soon.
