Old 06-23-2021, 12:02 PM   #1
TagMan
Default 1936 Headlight Lens Retainer clips
I purchased headlight lens retainer clips from C&G (below with an original Ford clip) for retaining '36 headlight lenses and they don't come close to fitting. Can't really blame C&G (although they should have received complaints about them) as C&G got them from Vintique.
Is there any vendor selling the correct clips for the '36 headlight lens ? I checked Bob Drake and the ones they show appear to be the same as the ones from C&G
Thanks,
-Bob
20210623_092527 (2) by TagMan, on Flickr
TagMan is offline   Reply With Quote
Old 06-23-2021, 02:28 PM   #2
nickthebandit
Default Re: 1936 Headlight Lens Retainer clips
I have used many of the replacement headlight lens retainer clips. No one that I know of makes the correctly configured headlight lens clip. Use a pair of pliers to bend the upper part of the clips, and they will work.
nickthebandit is offline   Reply With Quote
Old 06-23-2021, 09:42 PM   #3
TagMan
OK, thanks, Nick. I figured that was what I would have to do.
Old 06-23-2021, 10:22 PM   #4
VeryTangled
VeryTangled's Avatar
Originally Posted by TagMan View Post
Is there any vendor selling the correct clips for the '36 headlight lens ? Thanks, -Bob
I have to say I hate those repro's and can't make myself be patient enough to get them to work correctly. They have both the wrong shape and the wrong spring/stiff ratio. (Ford knew their springs!) Those headlights are fiddly enough trying to assemble without the pain of the wrong part!
Try Michael Driskell at 844-327-5988 (he may be away on vacation?). His website thirdgenauto.com doesn't show them but I understand why.
I know there were a bunch of the originals at Hershey a couple of years ago as I recall in both the V-8 Foundation trailer and in Bob Jones' booth. Michael may have ended up with some of them. I'd judge they are worth searching for.
-Jeff H
Have you thought about supporting the Early Ford V-8 Foundation Museum?
VeryTangled is offline   Reply With Quote
Old 06-24-2021, 09:26 PM   #5
TagMan
Thank you, Jeff. I'll give him a call.
Old 06-25-2021, 09:45 AM   #6
35fordtn
35fordtn's Avatar
We likely have them NOS, however we are away until July 5th. The vintique clips I have used on 35’s and 35-39 pickups with no issues. You do have to bend them outward a bit but I just installed some vintique ones on my pickup three weeks ago.
35fordtn is offline   Reply With Quote
Old 07-04-2021, 07:25 AM   #7
cajunfirehawk
cajunfirehawk's Avatar
Angry Re: 1936 Headlight Lens Retainer clips
36 lights are some of the most frustrating headlights to get together correctly, IMHO
Regards,
Todd
1936 FORD Tudor Slantback
"cajunhotrodder" on instagram/youtube
cajunfirehawk is offline   Reply With Quote
Old 07-04-2021, 07:46 PM   #8
jfcrash
jfcrash's Avatar
TagMan
Check out an old post “Headlight Lens Retaining Clips”
Jim
______________________________________________
jfc
I couldn't repair the brakes, so I adjusted the horn louder....
jfcrash is offline   Reply With Quote
Old 07-04-2021, 07:55 PM   #9
Gene F
Gene F's Avatar
They look like the same ones from my Model-A. Try talking to Snyders.
Gene F is offline   Reply With Quote
Old 07-04-2021, 10:12 PM   #10
cajunfirehawk
Exclamation Re: 1936 Headlight Lens Retainer clips
Originally Posted by jfcrash View Post
TagMan
Jim
HERE
https://www.fordbarn.com/forum/showt...etaining+Clips
Regards,
Todd
Old 07-05-2021, 08:15 AM   #11
Heard
Heard's Avatar
I ended up making some for my '35 pickup from some binder clips.
The stainless thingy is almost the right shape. A little tweaking and you're done.
Do I look like I have a plan B?
Heard is offline   Reply With Quote
Old 07-05-2021, 09:42 AM   #12
tubman
tubman's Avatar
Ingenious!
And cheap!
