11-04-2022, 08:56 PM | #1 |
is this an OE early fomoco part/setup?
Saw this on a flathead for sale, caught my attention, is this a real early ford setup?
Regards, Todd 1936 FORD Tudor Slantback "cajunhotrodder" on instagram/youtube |
11-04-2022, 09:04 PM | #2 |
Re: is this an OE early fomoco part/setup?
I don't know if that was available, or a one off home made deal.
Looks like an attempt at crankcse ventilation without a PCV valve. Sal |
11-04-2022, 09:06 PM | #3 |
My thoughts exactly, in my case I get a good bit of oil smoke and that would be ideal...
11-04-2022, 09:48 PM | #4 |
Period aftermarket accessory breather sometimes just routed down under the engine and not into the air cleaner. Regards, Kevin.
11-04-2022, 09:49 PM | #5 |
Not from factory.
11-04-2022, 11:36 PM | #6 |
Alan |
11-05-2022, 01:25 AM | #7 |
11-05-2022, 08:35 AM | #8 |
I was lucky as a kid to witness a crankcase explosion. A car was climbing the hill in front of my Uncle's Gulf station.
There was a loud BOOOM and the car had a rainstorm of oil and smoke beneath it. Naturally it was towed away.
Enjoy yer day. Tom Hate can't fix what it started. |
11-05-2022, 08:55 AM | #9 |
No, it is not Ford OEM.
11-05-2022, 10:06 AM | #10 | |
Really had nothing to do with 'emissions control' but had to do with the blow-by stink. Could be purchased at stores like J C Whitney etc.
11-05-2022, 09:50 PM | #11 |
Those breather tube filler caps were used on a lot of model As and may still be available. It was always an aftermarket item but I've never seen it used that way.
11-07-2022, 08:32 AM | #12 |
They Old Man had a 62 Falcon with blow by so bad that he put a piece of heater hose from the breather pipe to the air cleaner intake. Worked for him.
