Old 05-02-2011, 10:20 AM   #1
365356
Default '56 Fordomatic
Sigh. After working on trying to rebuild my fordomatic, I am about to admit defeat. I went through the transmission, admittedly it was my first. I followed the shop manual and replaced every thrust washer, the front pump and impeller hub because they were damaged. I put it back in, refilled, started the car and it leaked terribly and won't move. What are my options for replacements? How hard is it to convert to a later year transmission? I hate to change it, but the car is wasting away for lack of a transmission. I hate that even more. If it is something one of you has done before, I'd appreciate a little guidance. The engine is a nice 292 Y-block that runs great and I want to at least keep it.
Thanks in advance.
365356 is offline   Reply With Quote
Old 05-02-2011, 11:45 AM   #2
Dave72dt
Default Re: '56 Fordomatic
I can venture some guesses but I'm not familiar with the internals of a Fordomatic. I assume there is a seal in the front, may have been damaged ofr incorrect. The wear surface on the torque converter may be excessively worn where the seal rides. If the trans has a sprag clutch in it, there is the possibilty of it being in backwards. Band adjustment is always a possibilty and valves sticking in the valve body. Damaged piston seals internally.
If the torque converter didn't go all the way on or dropped partially back out during install, the pieces in the front of the trans may be damaged, again.
It'll have to come back out either to repair or replace.
Good luck.
Dave72dt is offline   Reply With Quote
Old 05-03-2011, 07:25 AM   #3
Dee
It could be as simple as the front seal was installed backards allowing a massive leak and pressure loss from the front pump.
Dee is offline   Reply With Quote
Old 05-03-2011, 01:17 PM   #4
JeffB2
JeffB2's Avatar
You may find some great advice here,it is an all Ford Transmission forum. www.network54.com/Forum/260730
JeffB2 is offline   Reply With Quote
Old 05-03-2011, 08:02 PM   #5
hotrodart
hotrodart's Avatar
If you wish to convert it to a stick shift....all the parts from a stick shift donor are 100% bolt-ins. Not a difficult change out. I did it in a few hours without helpers. If you want the column shifter, you will need to swap that also.
hotrodart is offline   Reply With Quote
Old 05-04-2011, 01:03 AM   #6
Daves55Sedan
Daves55Sedan's Avatar
You replaced the CONVERTER hub ? Thats probably what the problem is. Did you compare the depth of the new converter hub with the original one before installing it ?
If you acquired the hub that is deeper than the original, it would be a big problem.
Daves55Sedan is offline   Reply With Quote
Old 05-04-2011, 07:00 AM   #7
365356
The impeller hub was the same depth as the original.
