Old 01-24-2022, 05:37 PM   #1
zuburg
zuburg's Avatar
Default Seat back on 1956 Tbird came disconnected from bottom seat
While working on the soft top, I noticed the seat back was not connected to the bottom seat. I found a broken shaft or stud nearby and figured that was the culprit. I couldn’t find any such parts or images on how the seat is put together in any of the parts catalogs or the shop manual I have.
Can anyone confirm the stud in the picture is what holds the seat back to the bottom seat? Is it just a stud that a hole in the seat back slips over? Any idea where to get a part like this or something I could use in place of it?
File Type: jpg 46F0759E-633F-4963-B2D5-102E52F4E09D.jpg (54.3 KB, 27 views)
File Type: jpeg F9B556D0-3CA2-440C-8555-F18F074DD98F.jpeg (129.3 KB, 25 views)
File Type: jpg CB80D1F4-E936-42FC-84CF-5EB996361AC4.jpg (56.7 KB, 25 views)
zuburg is offline   Reply With Quote
Old 01-24-2022, 06:40 PM   #2
CSPIDY
CSPIDY's Avatar
Default Re: Seat back on 1956 Tbird came disconnected from bottom seat
Yes the stud holds the seat back to the base one on either side
Held with a cotter (split) pin
CSPIDY is offline   Reply With Quote
Old 01-24-2022, 06:44 PM   #3
zuburg
zuburg's Avatar
That’s what it looked like to me. Any idea where one would get that stud?
Does the cotter pin hold the stud in the base or hold the seat back on the stud? (Under the vinyl that covers the hole)
Old 01-24-2022, 07:50 PM   #4
CSPIDY
CSPIDY's Avatar
Maybe the stud could be welded back to the base
The pin hold the seat back to the base
Old 01-24-2022, 08:18 PM   #5
dmsfrr
dmsfrr's Avatar
Yes the stud is supposed to be part of the arm at the bottom of the seat-back. It looks like the original weld on the outer flat side may not have been sufficient, allowing it to fall out.
Pull the vinyl boot off of the arm and you should see the empty hole where the stud fits in. Put the stud all the way back in with a clamp or two keeping it tight and give it a quicky welding job. That should fix it.
If you need a picture of either side of the lower arm and stud without the vinyl cover, I've got another seat-back here that's out of the car and fairly easy to get to.
Example photo is of the passenger side...
dmsfrr is online now   Reply With Quote
Old 01-24-2022, 08:35 PM   #6
zuburg
zuburg's Avatar
Ah, got it. I thought the stud broke off, but a broken weld makes sense looking at how Kmart it looked.
Old 01-25-2022, 12:36 PM   #7
55blacktie
Having stripped all of the upholstery and foam from my 55 Tbird seat, I can tell you that the quality of the welds is pretty poor. I'm no welder, but I think I could have done as well/better.
55blacktie is offline   Reply With Quote
