Old 01-29-2014, 10:29 AM   #1
Jades
Default In need of a measurement
I searched every where but no definite dimension.... I have a 1930 Tudor, I need the front dimension from outside post to outside post at the top of front of car. I cut and replaced the the front header shelf and want to make sure the figment is okay before welding. Thank you...
Jades is offline   Reply With Quote
Old 01-29-2014, 12:04 PM   #2
Jades
Default Re: In need of a measurement
Thank you very much, I missed by 1/2 an inch, now I can get on with my project.
Old 01-29-2014, 12:08 PM   #3
marcshall
maybe you should put the window in ,that should tell you . are the doors on
marcshall is offline   Reply With Quote
Old 01-29-2014, 12:17 PM   #4
Jades
Yes the doors are on, the windshield hinge is very tight between the pillars, if I can spread the pillars another 1/4 inch or I trim the outside edges of hinge which I would not rather do. This car was hit hard in the past and was repaired half ass, seems a lot of bad bends in front body section.....
Old 01-29-2014, 12:31 PM   #5
Jades
Originally Posted by 1930 coupe View Post
Set the visor on it and see if the screw holes in the front of the post line up.
Thanks for the tip, I tried your suggestion and the screw holes miss by 1/4 inch, I guess Will have to spread the posts some how.
