Old 01-10-2022, 11:37 PM   #21
fordor41
fordor41's Avatar
Default Re: 1941 Ford Open Drive Conversion
Originally Posted by TJ View Post
Yes it is strong enough. I've been around this stuff for a long time and I've yet to see a failure of the Ford frame using a parallel leaf spring kit. Manufacturers put a lot of engineering into what they make and factor safety into the equation The last thing they need is bad publicity and a lawsuit.
I wouldn't really say they all put a lot of engineering into their spring set-ups. Chassis Eng. sold a ton of rear springs for 41-48 Fords. I believe they used Dodge van front springs. believe because the stock spring located the axle correctly in center of wheel openning. BUT if you had a problem, you were the only one with that problem. I saw an old instruction sheet that said "these springs may ride too soft or gravel truck rough. If too stiff, shorten the leaves, if too soft add leaves". They found a set of springs inthe 70's or so that worked and they stuck with those springs until they went out of business. just my opinion.
fordor41 is offline   Reply With Quote
Old 01-11-2022, 08:00 AM   #22
Ol' Ron
Ol' Ron's Avatar
I try to use rear axles with 5 on 4 1/2 bolt patters because of the vast verity of wheel sizes available. I like to run 16" x7 rims as the 13 inch tires are on their way out. Most junk yards just sell them for aluminum so a nice set of rims can be had for just a few bucks. Plan ahead.
Gramps
