01-29-2020, 01:35 PM | #1 |
Broke down
Rode home on a burro. The truck was giving some trouble, running bad, then died. From reading this forum, I'm guessing condenser or coil. Maybe fuel pump. I've got some spares, a condenser from JC Whitney, a coil I found at the mine, and a fuel pump from Western Auto. Should be good to go. Going this weekend to fix it and drive it home.
01-29-2020, 01:41 PM | #2 |
Re: Broke down
It's worth the effort!
01-29-2020, 01:43 PM | #3 |
Re: Broke down
Looks like Bonnie and Clyde left it there. I thought the burro broke down. Your plan sounds solid to me, good luck with getting the dwell set correctly.
01-29-2020, 01:47 PM | #4 |
Re: Broke down
The perfect start for your rat rod, might even come with some.
01-29-2020, 02:12 PM | #5 |
Re: Broke down
It sounds like you have enough parts to get it running. You might want to bring another battery also because there is a good chance that the battery will be dead also.
01-29-2020, 03:35 PM | #6 |
Re: Broke down
Tom |
01-29-2020, 04:03 PM | #7 |
Re: Broke down
Don't forget the Marvel Mystery Oil
01-29-2020, 04:17 PM | #8 |
Re: Broke down
If the pedal goes to the floor you may have a little air in it ,
01-29-2020, 04:21 PM | #9 |
Re: Broke down
When it's running again, consider giving the donkeys a ride home.
DD658 |
01-29-2020, 04:34 PM | #10 |
Re: Broke down
Better bring plenty of beer, looks pretty hot there and a air tank to blow up the tires.
01-29-2020, 04:46 PM | #11 |
Re: Broke down
It'll buff right out.
01-29-2020, 04:56 PM | #12 |
Re: Broke down
Nice patina....also well ventilated.....
01-29-2020, 05:08 PM | #13 |
Re: Broke down
Eastwood sells “patina preserver” for that!
It’s all the rage to leave it as found. Watch out for snakes! |
01-29-2020, 05:09 PM | #14 |
Re: Broke down
Straighten the grill and get some stainless trim items and she's good to go.
Bruce
Works good Lasts long time |
01-29-2020, 05:29 PM | #15 |
Re: Broke down
Looks like it was used too much when it was new .
01-29-2020, 09:44 PM | #16 |
Re: Broke down
Ran when parked. Came with a standard 2 burro ford engine. Just needs tlc.
01-29-2020, 09:48 PM | #17 |
Re: Broke down
SO you got air -con....?
01-29-2020, 10:20 PM | #18 |
Re: Broke down
the mugruder valve has to be stuck, take along a BFH, we sailors could fix anything with that!!
01-29-2020, 11:14 PM | #19 |
Re: Broke down
right front tire looks low to me, keep her under 55.
1928 "A" Phaeton (mid year with many early features) 1933 "V8" Closed-Cab Pickup Truck (originally a Model B, 4 Cylinder dating to May, 1933)
01-30-2020, 12:28 AM | #20 |
Re: Broke down
I'd say you found yourself a real jewel right there. Enjoy!!
