09-05-2015, 12:04 AM | #21 | |
Re: Float-A-Motor mounts
TRUST ME, the motor & power train DOES NOT move back & forth with Float-A-Motors. They only suppress the engine noises from getting into the frame/body. The name of them is mis-leading, they should have been called, "QUIET-A-MOTOR" Old tales abound & KEEP on being REPEATED! Some may confuse them with early Chrysler mounting systems, called, "FLOATING POWER." I've heard NIEVE persons that even think your fan could go into the radiator during a sudden stop----------------HOGWASH!! Front & rear FAMS were the GREATEST thing I ever did to Minerva, I'd put them on Vermin, except, I'M TOO TIRED! At 60-65, Minerva just went HMMMMMN, so smooth & quiet, you wouldn't believe it. With stock mounting, she sounded like you were TEARING up the engine, after 45MPH! You're familiar with those sounds & that's why many don't drive over that speed. Bill W.
09-05-2015, 12:27 AM | #22 |
I agree with Bill Williamson. The first post was a question on the safety of FM and Bill answered the question. I have used FM for 30 thousand miles with no problems and it sure make installing the engine easier than with original mounts. Why do you think they sell after market frame spreaders for help in engine replacement with original type mounts.
09-05-2015, 12:30 AM | #23 |
never had to use a frame spreader on OSM's
09-05-2015, 12:58 AM | #24 |
To the OP:
What no one is telling you is that in order to install the B transmission with the B engine you must use a Model B flywheel housing. There is no provision on the B flywheel housing for attachment to Model A rear motor mounts, so the stock rear engine mounting is out of the question for that combination. The Model B flywheel housings were made in two configurations; one with a demountable ear on each side for connecting the steady rods used to control fore and aft movement on the later model Fords with the "improved" four cylinder and V8's. That flywheel housing is used to install the B engine and transmission in a Model A frame using a special version of the Float-a-Motor mounts. The FAM's for installing a B in an A are not the same as the ones used for the Model A engine installation. Your only choice will be the special FAM's or a home-made mount if you have the ability to fabricate it using the B flywheel housing. I made a set using large steel angle and V8 motor mount biscuits; it can be done! |
09-05-2015, 02:27 AM | #25 | |
Best regards Chris 1930 Ford A Std. Tudor |
09-05-2015, 03:51 AM | #26 | |
To be 'politically correct', I am just going to say that based on my experiences with Float-a-Motor mounts, by design they DO allow the engine & transmission assembly to move back & forth. In addition, it has been my experience that this movement DOES affect the braking efficiency of a stock braking system. If anyone chooses to disagree, that is OK too. As they say, experience is generally something you get after you need it. I just know what I have experienced on multiple occasions! |
09-05-2015, 06:53 AM | #27 |
Always confusing, It seems all conversations are 50/50, I guess there will never be a 100% agreement on the mechanics of the Model A.
09-05-2015, 07:37 AM | #28 | |
-Mike Late 31' Ford Model A Tudor, Miss Daisy I don't work on cars --I'm learning about my Model A. Cleveland, Ohio |
09-05-2015, 09:25 AM | #29 |
09-05-2015, 09:39 AM | #30 |
To the OP: What no one is telling you is that in order to install the B transmission with the B engine you must use a Model B flywheel housing. There is no provision on the B flywheel housing for attachment to Model A rear motor mounts, so the stock rear engine mounting is out of the question for that combination. The Model B flywheel housings were made in two configurations; one with a demountable ear on each side for connecting the steady rods used to control fore and aft movement on the later model Fords with the "improved" four cylinder and V8's. That flywheel housing is used to install the B engine and transmission in a Model A frame using a special version of the Float-a-Motor mounts. The FAM's for installing a B in an A are not the same as the ones used for the Model A engine installation. Your only choice will be the special FAM's or a home-made mount if you have the ability to fabricate it using the B flywheel housing. I made a set using large steel angle and V8 motor mount biscuits; it can be done! I do have the B flywheel housing, oil pan, etc. I have everything I need. I already decided to adapt some kind of modern motor mounts and do it myself, as this is certainly not out of my skillset. I'm 50yo, have worked as a bodyman, as a production welder among other things. So I am just going to make my own mounts. Quite interesting responses here for sure. Lol |
09-05-2015, 01:22 PM | #31 |
With FRONT FAM's, be SURE to enlarge the crossmember holes, from below, with a UNI-BIT, otherwise, the engine vibrations will transmit from the mounting bar to the crossmember, through the bolt & it would vibrate WORSE than stock! The sellers should mention this, in their installation instructions.
I had to install 2 heavy flat washers under the engine bar, to align the crank bearing, to the crank nut. The Dog calls me a "CRANK NUT"---Whut duz he mean??????--I'm nice to him?? Bill W.
09-05-2015, 07:15 PM | #32 | |
TOO MANY bored old Dudes, with nothing else to do, except RATTLE about stuff & see their NAME in PRINT! Why are so many folks INSECURE?--YES, I'm insecure, also & slightly paranoid, at times. Am I NORMAL? At least, I can make a Model A run & operate properly & right now, I'm baking Cranberry Yeast Bread. Next, I have to wash my BOTTLES Bill W.
09-05-2015, 07:41 PM | #33 |
the drive train will move a little with the F.A.M that's ok. but they do sag allowing your motor to drop in the rear (crank hole will not line up) also never use with t5 open driveshaft or any other open drive shaft conversions.
09-05-2015, 08:07 PM | #34 | |
Bill W.
09-05-2015, 09:18 PM | #35 |
The extended cab 29 CCPU in my avatar has FAM's, open drive shaft and a T-5! Never had any issues in almost 10 years. Also has a B engine, original CRAGAR head and F-100 steering. The frame is straight and there's zero sag. Absolutely great touring car. There's even enough room in the bobbed flatbed to carry four cases of beer!
No restorable Model A's were harmed in the building of this truck! |
09-06-2015, 03:28 AM | #36 | |
btw, I used to subscribe to F.A.S.T. and Secrets, so I understand lol. |
09-06-2015, 04:02 AM | #37 |
I have noticed since installing FAM that I have become Lactose Intolerant.
09-06-2015, 04:09 AM | #38 |
Thank you for the tip on enlarging the 2 holes in the front crossmember. I preformed this very delicate operation this morning, assisting was my able body wife and boxer Sara. Boat tail Speedster is coming along nice. I want to go to T R O G in the worst way! Thanks again Bill. Don
09-06-2015, 04:16 AM | #39 |
I really enjoy this Ford Barn At least here we can be funny and learn some thing. And thats all I got to say about that! Don
09-06-2015, 08:28 AM | #40 |
i'm lucky to have Bill as my POP.. when he see's something works he tries to pass that on to others with a joke included...
i caught him last night trying to install FAM's on both my cars.. |
