06-30-2015, 10:30 AM | #1 |
8BA ignition
What distributor coil combination is working best for folks with a modified 8BA ?
I am very happy with the Mallory electronic setup on my truck but it is a little pricey. So I am considering a pertronix Ignitor for this build but I have heard good and bad about the loadmatic vacuum only distrubutor. I have a H&M 400Jr regrind and plan to use either three 94s or the 4160 Holley I have on hand. thanks in advance for you opinions
3 pedals, 3 gears, no valve-covers.. Now THAT is a hot rod !! https://www.youtube.com/watch?v=ZmwwB34vxJE |
06-30-2015, 10:33 AM | #2 |
Re: 8BA ignition
Why not use the Chevy setup?
06-30-2015, 10:53 AM | #3 |
Re: 8BA ignition
Once you add a camshaft and multiple carbs you no longer have proper vacuum to control the loadamatic vacuum only distributor...
At this point you have a number of options ( all of them aftermarket) |
06-30-2015, 11:01 AM | #4 |
Re: 8BA ignition
Also, adding things to the Loadamatic is pretty much a waste of time. It makes sparks just fine if you know the little diddly things to check and can get decent points from NAPA. Its problems are all in the advance, even on a stocker, and really require its replacement.
06-30-2015, 02:13 PM | #5 |
Re: 8BA ignition
I would say...let Bubba help you through this one.
06-30-2015, 02:17 PM | #6 |
Re: 8BA ignition
06-30-2015, 03:00 PM | #7 |
Re: 8BA ignition
Thanks guys I will PM Bubba
06-30-2015, 03:13 PM | #8 |
Re: 8BA ignition
Bubba will convert a GM dist to operate on centrifugal and vacuum advance, thus giving both power and economy when needed, the only aftermarket unit that can do this,s the MSD. However, that would have to be setup to operate a Flathead properly.
Just curious, Why did you select the 400jr cam?? This is an excellent cam for racing especially on a short track. However the reliably factor for a street engine is marginal. |
06-30-2015, 07:23 PM | #9 |
Re: 8BA ignition
I have been using an early 1980's 318 chryco electronic unit with the orange coloured ign module. About an hour with a small lathe to re work to fit an 8ba. E mail me at [email protected] if you want more info.
07-01-2015, 02:21 AM | #10 |
Re: 8BA ignition
I usually take an mallory mech adv from a SBC (they are cheap used) and put it in the lathe.
A mech/vac like bubbas has some pros over the mech only, and having it readily tuned for your aplication saves you a few hours tinkering... |
07-01-2015, 08:00 PM | #11 | |
Re: 8BA ignition
Here are my "Frankenstein" Big Cap Chevy distributor (parts of two different distributors grafted together) and my Crane ignition with HEI backup under my '53 dash. Both have been flawless for about three years now. |
07-02-2015, 07:18 AM | #12 |
Re: 8BA ignition
Richard,
Your Frankenstein distributor, could you elaborate on why it's two crafted together please? Could you not just machine a regular che7y HEI and use that? Thanks, Martin. |
07-02-2015, 09:14 AM | #13 | |
Re: 8BA ignition
The shaft, however, with a little trickery, was long enough and didn't need lengthening. I have lots of pictures if you're interested in trying it. |
07-02-2015, 09:50 AM | #14 |
Re: 8BA ignition
I cut down a chevy points distributor for my mild 50 merc motor. It ran pretty good, but without being able to recurve it to whatever Bubba does, it never was as good as the Bubba's distributor. Rich
07-02-2015, 07:28 PM | #15 | |
Re: 8BA ignition
Do you have access to a distributor machine? The secret is in the springs and in setting the advance RANGE. Other important factors are gear alignment and shaft end play. Happy to help if you have questions. |
07-03-2015, 01:45 AM | #16 |
Re: 8BA ignition
Thank you for your explanation Richard, didn't know the length difference on the HEI.
Deuce man, As Richard said, curve wise, it's springs and advance range. If useing a recurve kit, lightest springs are normally the ones, lighter would be nice. Normally make my own advance stop bush. The advance, in my opinion needs to be tailored to the car spec, engine spec and intended use. If your gonna do it, do it right. Martin. |
07-03-2015, 03:10 AM | #17 | ||||
Re: 8BA ignition
Oh, I did make my own distributor machine from some scrap wood, some hardware odds and ends, and a sewing machine motor. Works great! |
07-03-2015, 08:59 AM | #18 |
Re: 8BA ignition
You should see his road machine, checks advance, AF, vacuum,and records this on tape for further use. Nice guy to have around.
07-03-2015, 12:11 PM | #19 |
Re: 8BA ignition
Ol' Ron is referring to my "Road Rig," a diagnostic package I dreamed up to monitor manifold vacuum, engine RPM, A/F ratio, and actual real-time advance... and it records all this on video tape along with my running field commentary. It ain't nuclear physics but it's a terrific diagnostic tool.
07-03-2015, 01:09 PM | #20 |
Re: 8BA ignition
You got more test gear than I have Richard, love the dizzy machine and the road rig.
I think you can safely claim the advance stop screw as your baby too. If you were a cartoon character you'd have a light bulb above your head constantly. Really admire your "Git er done" mentality. Martin. |
