Old 09-30-2021, 10:23 PM   #1
Derek1937
Default 1937 aluminum intake problems
I have a 1937 ford pickup that I’ve been using aluminum intake manifolds on and for some reason it keeps burning holes in the back of them or cracking am I doing something wrong or is some repair for this? Thanks
Derek1937 is offline   Reply With Quote
Old 09-30-2021, 11:17 PM   #2
Brian
Brian's Avatar
Default Re: 1937 aluminum intake problems
Well Derek, an aluminum manifold made in 1937 is now 84 years old....I too have experienced this problem...one easy solution is to plug the heat riser holes each side of the manifold, either in the block, or in the manifold, or keep trying different manifolds until you find one that works...and welcome, how about some photos of your 37?
Old 10-01-2021, 12:56 AM   #3
ford38v8
ford38v8's Avatar
Derek, Brian has offered a workable solution, for which I can elaborate and also offer a compromise solution...
The heat riser holes in the block are of a size that matches nicely with a penny, to be gently tapped into each of the two holes. Due to the alloys of modern pennies, a wheatstalk penny is recommended.
As this fix may cause unwanted consequences, I have a compromise solution to offer...
Do as advised above, but also, drill a 1/8" hole in the center of each penny.
Alan
Old 10-01-2021, 07:37 AM   #4
JM 35 Sedan
JM 35 Sedan's Avatar
A bit of trivia ......if you can't find a US wheatback, or wheatstalk penny, you can use a US memorial back penny minted from 1959 to 1981, which is the same composition as the "wheaties" pennies. US pennies made after 1982 are 95% zinc and will not withstand the exhaust heat or work for very long.
John
Old 10-01-2021, 08:18 AM   #5
Derek1937
Okay thanks for the information I’ll try to figure out how to put a picture of the truck on here this is my first time using it. I tried the penny trick a year ago but the truck wanted to run really rough and had to be about half choke to run. I thought maybe it was a vacuum leak so I put a gauge on it and it had lots of vacuum. Would drilling the 1/8” hole in the penny help this?
Old 10-01-2021, 08:37 AM   #6
Bill OH
I plugged the heat riser on my 221 with core plugs driven into the block. Those do not melt or blow out.
Bill OH is offline   Reply With Quote
Old 10-01-2021, 11:45 AM   #7
flatjack9
flatjack9's Avatar
Yes
Old 10-01-2021, 03:57 PM   #8
Derek1937
Okay perfect thanks I’m going to try it out right away!
Old 10-01-2021, 04:01 PM   #9
Derek1937
I have another good one but is it at all possible to fix the ones that have burned the holes in them?
Old 10-01-2021, 05:30 PM   #10
JSeery
JSeery's Avatar
As a side, in the day, the year of the penny used was your birth year.
Old 10-01-2021, 05:46 PM   #11
Derek1937
My truckhttps://imgur.com/a/9XTOaUV
Old 10-01-2021, 05:56 PM   #12
petehoovie
petehoovie's Avatar
Old 10-01-2021, 07:39 PM   #13
JM 35 Sedan
Nice looking '37 pickup. I've always felt the '37 PU had the best looking grille in the years from '35 to '39.
John
Old 10-01-2021, 08:02 PM   #14
Derek1937
Thanks that’s awesome I’m working on bringing it back to 100% original I have the frame and motor all fixed up just like new
Old 10-01-2021, 08:54 PM   #15
cas3
Nice truck! looks like that grill could be fixed with some skillful tinkering
Old 10-01-2021, 09:21 PM   #16
Derek1937
Ya actually I bought a 1937 2 ton the rest of the truck was destroyed but the grill or any of the Chrome was perfect pretty amazing. Just waiting for the right time to put it on
Old 10-01-2021, 09:24 PM   #17
Derek1937
I’m not sure if it worked or not but this is the new grill
Old 10-01-2021, 09:25 PM   #18
Derek1937
Old 10-02-2021, 05:58 PM   #19
hotcoupe
hotcoupe's Avatar
Dereck, that's a good lookin' truck, but i believe your front bumper is on upside down.
Tom
hotcoupe is online now   Reply With Quote
Old 10-03-2021, 10:06 AM   #20
Derek1937
[QUOTE=hotcoupe;2062660]Dereck, that's a good lookin' truck, but i believe your front bumper is on upside down.
Tom[/QUOTE
You now I think your right I’ve never even noticed that my great uncle had the truck before me and put it on. So is the back bumper supposed to be the same way up as the front one?
