07-25-2021, 11:59 AM | #1 |
Key start
Back in March there was a thread about using a starter solenoid with links to other similar threads. CarlG wrote that he uses a key start on his A. I have long thought that the push button on the left side of the dash on Ford trucks was a cool feature, but an ordinary key start would be better. I had an off-the-shelf switch on my 57 Chevy truck, but I recall that it was too bulky to fit in the available space behind an A dash panel. If my memory is correct, what type of ignition switch would fit there, or would it be necessary to install it in the dash rail?
07-25-2021, 02:44 PM | #2 |
Re: Key start
I would think twice about using a key start setup. I purchased a 1931 sedan that had one. To start the car, I had to reach through the steering wheel of the car to turn the key, while I used my right had to pull the chock. A left had mounted push button would work better.
Bill Cilker, Jr Unrestored 190A Victoria 45B, 160B & 189A Victoria Association President |
07-25-2021, 03:17 PM | #3 |
Re: Key start
My experience is all in repairing it, not driving it--I forgot about the choke.
07-25-2021, 03:33 PM | #4 |
Re: Key start
Snyder and other venders has a kit called "sparky", where it is connected to the spark lever rod to activate the starter. I made my own similar one, with the same results, and
it works great. Look it up on one of the venders, you might just like it.
IN GOD WE TRUST - SEMPER FIDELIS John |
07-25-2021, 04:00 PM | #5 |
Re: Key start
I saw the sparky in a website and it has some appeal, but I would fear pushing the spark lever to full retard for reason other than starting, and having my starter drive voice a loud objection
07-26-2021, 12:45 AM | #6 | |
Re: Key start
07-26-2021, 01:56 AM | #7 | |
Re: Key start
David Serrano |
07-26-2021, 08:00 AM | #8 |
Re: Key start
I like a push button starter on the dash, if your on an incline you can use one foot on the clutch and one one the brake to restart the engine.
07-26-2021, 08:24 AM | #9 |
Re: Key start
I'm curious. What does "pulling the choke a couple of times before I press the starter" do beside open and close the choke butterfly? It surely will not enrichen the mixture if the engine is not spinning.
07-26-2021, 09:37 AM | #10 |
Re: Key start
Me too!!
07-26-2021, 09:41 AM | #11 | |
Re: Key start
Don't disparage the guy. |
07-26-2021, 10:09 AM | #12 |
Re: Key start
Perzactly.
07-26-2021, 10:11 AM | #13 |
Re: Key start
No disparage, just curiosity.
07-26-2021, 11:48 AM | #14 |
Re: Key start
07-26-2021, 12:06 PM | #15 |
Re: Key start
07-26-2021, 12:18 PM | #16 |
Re: Key start
Probably spell check assisted David. It's pesky.
07-26-2021, 01:01 PM | #17 |
Re: Key start
I don’t know, I’ve just been doing it for 7 years and it works for me and it starts on the first or second time I press the starter even after it sits for some time. I only press the starter for one or two revolutions and stop. If it doesn’t start the first time it’ll start the second time I press the starter.
Maybe just a good engine and carburetor. Never had to mess with anything. The previous owner said he had a mechanic in Orange Co., CA that worked on the car regularly. I’ll just keep doing it until it doesn’t work. I don’t like to mess with mysteries of the universe. David Serrano |
07-26-2021, 02:47 PM | #18 |
Re: Key start
If you don't touch the choke knob does it start the same?
07-26-2021, 03:05 PM | #19 |
Re: Key start
That's the way I read it.
07-26-2021, 05:29 PM | #20 |
Re: Key start
