Old 06-29-2021, 11:32 PM   #1
Will D
Will D's Avatar
Default Piston opinions
For a stock budget build 59a, what is a decent piston to use? Not so cheap they are garbage but not an arm and a leg just for a "brand name".
Anyone used sealed power with any luck?
Sometimes, ingenuity gets in the way of sense and sanity.
Will D is offline   Reply With Quote
Old 06-30-2021, 05:07 AM   #2
Ol' Ron
Ol' Ron's Avatar
Default Re: Piston opinions
I've always used Eggy, but seal power is a good piston.
Gramps
Old 06-30-2021, 03:31 PM   #3
Desoto291Hemi
Egge are really good pistons,,,,good quality,,,,good price .
Like old Ron said. Sealed power are good as well .
Tommy
Desoto291Hemi is offline   Reply With Quote
Old 06-30-2021, 05:39 PM   #4
tubman
tubman's Avatar
I would go with Sealed Power" before Egge. The price is probably better, and I'll bet they have supplied thousands more pistons than Egge, who probably has "Sealed Power" make theirs.
Old 06-30-2021, 07:11 PM   #5
flatjack9
flatjack9's Avatar
I've used Sealed Power, but I'm not real crazy about the shape of their dome.
Old 06-30-2021, 07:23 PM   #6
Bored&Stroked
Bored&Stroked's Avatar
Do they use the "ellipse" style dome - pointy in the middle? I've seen this dome on some Egge pistons, some 4-ring Jahn's, and some Ford.
If so, then these pistons will not work with any of the aftermarket aluminum heads (which use a consistent radius dome) - the "pointy middles" will hit the heads if the squish is anywhere close to what it should be. The squish should be .040 to .050 for optimal performance.
This is the reason that I always try to find a consistent radius dome type piston - if using any aftermarket heads.
Here are some pics of the double-ellipse style domes shapes versus the consistent radius dome shapes that are on Ross pistons, Edelbrock heads, etc..
Here are the pointy domes - the shape necessary for the heads to work:
Here are the consistent radius somes - like Ross Pistons (again from the head dome perspective)
Here is the actual 2D sketch view that I use for 3 5/16 pointy pistons (when I machine the heads in a CNC mill)
Here is the Ross sketch I use:
Old 06-30-2021, 07:42 PM   #7
Ronnieroadster
Ronnieroadster's Avatar
Your statement about who makes Egges pistons is Wrong!
Egge casts and makes their own pistons as well as machines everything in house. How do I know you may ask I along with a large group of Hot Rodders visited their facility in California. We witnessed first had the pouring of aluminum into the molds to the complete machining operation. The pistons in stock on the shelfs in their warehouse was extensive.
As for Sealed Power making more pistons. When it comes to specialty pistons for all makes I think Egge is certainly one of the front runners in the amount of production they do.
Ronnieroadster
I use the F word a lot no not that word these words Flathead , Focus and Finish.
"Life Member of the Bonneville 200 MPH Club using a Ford Flathead block"
Owner , Builder, Driver of the First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 in one and a half miles burning gasoline.
First ever gas burning Ford flathead powered roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH
Old 06-30-2021, 08:02 PM   #8
tubman
tubman's Avatar
Ronnieroadster
I appreciate the information, but as I said : "probably". It is good to know that some of the specialty manufacturers still manufacture their own products, as it seems to become less and less common over time. However, it has no bearing on who makes the better piston or the relative costs.
I still have faith on the old line American manufacturers with a positive history and reputation. I would expect "Sealed Power" (Federal Mogul) to have access to better infrastructure and other resources than Egge.
Old 06-30-2021, 08:28 PM   #9
Ronnie
Ronnie's Avatar
Here is a good piston
https://uempistons.com/series-3888-s...-3-9-1058.html
United machine is a player
R
Ronnie is offline   Reply With Quote
Old 07-01-2021, 01:25 AM   #10
leon bee
I bought some Sealed Power pistons about 3 years ago. They were made in India. Looked pretty good to me. But that engine only has about 80 miles on it.
leon bee is offline   Reply With Quote
Old 07-01-2021, 08:45 AM   #11
Tim Ayers
R
Is Silv-o-lite their brand? That's what comes up when you click the options?
Old 07-01-2021, 09:39 AM   #12
Ronnie
Ronnie's Avatar
Yes all seen under options are united mach products.
R
Old 07-01-2021, 10:04 AM   #13
tubman
tubman's Avatar
I saw a "YouTube" video once where some guys with bare feet were pouring molten aluminum into holes in the ground. I hope it wasn't them.
Probably not.
Old 07-01-2021, 02:14 PM   #14
Ronnieroadster
Well Sealed Power certainly has other resources but not in the US! EGGE pistons made in the good old USA by American labor.
Old 07-01-2021, 03:09 PM   #15
flatjack9
flatjack9's Avatar
Attachment 467081
Attachment 467082
Attachment 467083
Attachment 467084
The dome does not extend to the edge of the piston. There is about a 1/16" flat before the dome starts.
Old 07-01-2021, 05:40 PM   #16
Will D
Will D's Avatar
Thanks for all the input. I'm using stock c59a cast heads. The more I look around at different pistons and threads on here, I am starting to see alot of the pistons vary on compression height and dome height. Starting to crunch some numbers in that regard as well to attain a decent squish/quench if I want to minimize machining and/or prevent the pistons from hitting the heads.
Old 07-01-2021, 05:42 PM   #17
Will D
Will D's Avatar
R
Ronnie, did you go to them direct or use one of their Canadian distributors?
Old 07-01-2021, 10:03 PM   #18
Ronnie
Ronnie's Avatar
Will D They only sell through their existing suppliers. They should be available at Lordco if not any ERI machine shop they all have access to United Machine.What part of BC are u in?
R
Old 07-01-2021, 11:19 PM   #19
Will D
Will D's Avatar
R
The ERI group, didn't know they existed, thank you. I'm in the interior, looks like closest one from their website is in Salmon Arm. Turns out I'm headed that way for work on Monday so that works out swell. I tried checking out Lordco today but being July 1st, the weekend guy was on shift.....you really have to talk to the right person to get what your after there!
Old 07-02-2021, 08:38 AM   #20
Ronnie
Ronnie's Avatar
Will here is the distributor list scroll down to canada and see results.
https://uempistons.com/c-29-silv-o-lite.html
There are 20+ ERI members in BC.ERI is dedicated to machine shops only. They probably will have to order them,but that won't be an issue.
R
