08-27-2010, 07:16 PM | #1 |
Battery Polarity HELP
I purchase my 1928 a few years ago, but it is now when I realized that the battery is connected negative to ground (as you can see, I rarely used the car) and now I am retaking the hobby and I have to replace the battery. (6 volts)
The question: what will happen if I reverse the connection (positive to ground)? I cannot find any markings on the starter motor or generator that will indicate that they are negative to ground. Was there any model A in 1928 built with negative to ground? Any procedure to follow, indication, hint, or help, will be appreciated..thanks
My A-28 is running but needs work |
08-27-2010, 07:44 PM | #2 |
Re: Battery Polarity HELP
No Model A Fords were built with Negative ground.
The Starter is not bothered by polarity. It will operate properly either way. Postive ground or negative ground. Install the new battery with the Postive post attached to the chassis. Polarize the generator using a small jumper wire momentarily connecting. to the rwo electrical connectionws on the cutout. If the ammeter reads backwards wth the generator charging, reverese the wires on the ammeter. I don't think I left anything out.
I noticed the harder I work the luckier I get! |
08-27-2010, 08:26 PM | #3 |
Make sure you have a stock cut out. You may damage some of the modified systems
08-27-2010, 09:16 PM | #4 |
All of what Mag said but if the coil is correctly wired for negative ground you will need to reverse the wires on the coil. It will run either way but it won't crank and run as well if the coil polarity is reversed.
Not to start a war here but if it was mine and it wasn't giving any problems with the negative ground hook up I would just put the new battery back the way the old one was. Otherwise your going to have to reverse four wires and polarize the generator. If you are running the can style regulator that is the negative ground type you will fry the regulator if you try jumping a wire across it to polarize. Also the negative ground regulator will not work on positive ground. So if you are now running a can style regulator you will have to buy a new one if you convert back to positive ground. Just a few thoughts to consider. Good luck. |
08-30-2010, 07:58 PM | #6 |
I will try to starting the motor, positive to ground, generator disconnected, to see if the cranking is better... then I'll work with the generator...will post results if any noticeable difference..thanks so much
08-30-2010, 11:37 PM | #7 | |
Charlie Stephens |
08-30-2010, 11:56 PM | #8 |
DO NOT RUN THE ENGINE WITH THE GENERATOR DISCONNECTED unless you ground the generator output terminal. A stock Model A generator not connected to the battery can put out about 40 volts and burn itself out.
Grounding the output stud keeps the generator output at zero. |
08-31-2010, 08:49 AM | #9 |
What about the horn when you change polarity? I don't know if it will run properly in either direction.
08-31-2010, 09:26 AM | #10 |
09-01-2010, 02:57 AM | #11 |
Thanks for the input once more! here there are some results: with positive to ground,
The cranking of the motor felt different and the car started sooner (go figure), the cranking seems smooth and less noisy!!! I did not ground the generator, however it was entirely disconnected and I hope it did not get damaged, because there is not excitation current going to it .. I do have the can type regulator and will try to re-polarize for a quick test (of course if the generator have magnets inside then I'll say it is fried)...
09-01-2010, 10:57 AM | #12 | |
09-01-2010, 12:26 PM | #13 | |
Charlie Stephens |
09-01-2010, 08:09 PM | #14 | |
1. You say you have the can type regulator. Are you calling the stock cutout a regulator, or do you know for a fact that you have a can type regulator made by John Regan? 2. You don't need to have the wire connected to excite the generator. The residual magnetism is what excites the generator and running it without being connected to the battery can make it put out up to 40 volts and it will fry itself if run for very long this way. I only run it this way for a few seconds to show people how many volts it can put out when disconnected from the battery. Sometimes the generator can loose it residual magnetism if it has sat idle for a long period of time. Simply supply battery voltage to the output stud to remagnetize the generator. The easiest way to do this is to use a short wire to jump the 2 cutout terminals for 1 or 2 seconds. If you have one of John Regan's can type regulators, he says DO NOT polarize by jumping across the 2 terminals. In that case, I'd remove the regulator and touch battery voltage to the generator output stud for 1 or 2 seconds, then reinstall the regulator. This way there would be no chance of burning out the regulator. |
09-04-2010, 10:14 PM | #15 | |
09-01-2010, 03:00 AM | #16 |
and... yes the horn worked with either polarity (I tried)...txs
My A-28 is running but needs work Last edited by cardoza; 09-01-2010 at 03:01 AM. Reason: verbs !!! |
09-01-2010, 11:11 AM | #17 |
Maybe it started better because when the former owner switched to negative ground they didn't change the polarity of the coil. So when you switched to pos. groung the coil worked as intended. I think Purdy is giving you good advise; neg. ground won't hurt abit.
My A is in pieces, almost back together. It didn't have any wiring so I put all that in, had the generator checked because I had no idea. It checked fine except it was polarized neg ground. I had the Generator guy put it back to pos ground. I almost had the wiring done, was checking my turn signals and the only way to get the flasher to work right (the indicator bulb on the handle) was to hook it up neg ground. So I switched wires on my coil, re-flashed the gen and switched the amp gauge wires. I will be running neg ground. |
09-04-2010, 07:57 PM | #18 |
Finally my car is positive to ground (I had to do it )
FINDINGS: Tom W: I used the wrong name it is a cutout!!! Purdy: you are right, high voltage generates when generator is not grounded my case 15 to 18 volts in a few seconds and ... MAG the amp-meter reads backwards... anyhow I used this link to learn more about what I have http://www.ytmag.com/articles/artint4.htm and I never knew about three brushes generators and settings for night driving!! anyhow thanks so much for the sound advice and warnings the put me back in the learning process..
09-05-2010, 07:07 AM | #19 |
If you have a Nu-Rex Alternator, is there any problem in reversing polarity??
Mine is still positive ground, and except for a spell of dark nights because I grounded the headlamps back to the Negative terminal of the battery, it works just fine as is.
20 years ago we had Johnny Cash, Steve Jobs, and Bob Hope. Now we have no Cash, no Jobs, and no Hope...please don't let Kevin Bacon die! |
09-08-2010, 02:43 AM | #20 |
I will say that if you get an alternator with a given polarity, one will not be able to change polarity due to the solid state hardware that comes inside it.. (...course I may be wrong..)
