09-22-2020, 12:02 AM | #1 |
starter solinoid
Question, I mounted a starter Solinoid on the firewall with two sheet metal screws. Does it require a clean metal surface for a ground? Thanks Stan
09-22-2020, 04:51 AM | #2 |
Re: starter solinoid
Normally any (if) needed ground will occur between the screws and the bare metal solenoid case.
After installation check continuity between solenoid case and engine.
09-22-2020, 10:35 AM | #3 |
Depends on what solenoid you are using. The original Ford solenoid grounded
through the start button and does not require a grounded base. |
09-22-2020, 12:31 PM | #4 |
No, it does not.
09-22-2020, 12:35 PM | #5 |
Thread Tools | |
Display Modes | |
