Old 04-06-2020, 01:46 PM   #1
bobmc
Default Tire Rotation
Its a bright sunny day here in western Pa. Practicing social distancing I am killing two birds with one stone. First i am getting the A ready for the green light that will allow our club to begin touring again, and second i am passing the time working on the car. Did all the usual preseason stuff, oil change,lube, tune-up, check brakes and packed wheel bearings. This brings me to my question. All four tires have enough tread with no cracks to allow me the entire touring season use. Since all four tires are off what is the thought on rotating the tires? How do you do it? Front on back, cross back tires and install on front?
thanks
Stay Safe!
Bob
bobmc is offline   Reply With Quote
Old 04-06-2020, 02:15 PM   #2
Gary WA
Gary WA's Avatar
Default Re: Tire Rotation
I do front/ back, back to front- but are they balanced?
www.whidbeymodelaclub.com
Old 04-06-2020, 03:37 PM   #3
Herb Concord Ca
I do like radial tires. Front to back and back to front.
Herb Concord Ca is offline   Reply With Quote
Old 04-06-2020, 06:49 PM   #4
Dale G.
Dale G.'s Avatar
I worked in gas stations and tire stores when I was a kid, we were always taught to rotate bias-ply tires, spare to left front, left front to right rear, right rear to right front, right front to left rear. right rear to spare.
Dale G. is offline   Reply With Quote
Old 04-07-2020, 04:26 AM   #5
shew01
shew01's Avatar
I’m curious. How do you balance Model A tire? Glass beads? https://www.amazon.com/DIYK-4-Counte...6251525&sr=8-6
If so, how many ounces per tire do you need to achieve a balanced tire?
shew01 is offline   Reply With Quote
Old 04-07-2020, 04:28 AM   #6
shew01
shew01's Avatar
Thanks for posting. I was wondering about the tire rotation pattern.
Old 04-07-2020, 06:25 AM   #7
old31
On the beads you use 4oz per tire.
i firmly believe in them but could never get them to enter the stem, both with a metal and rubber stem. Tried many times with vibration, small funnels, gave up.
I purchased a HF tire balancer and used stick on weights just on the inside and painted them tire color.
Old 04-07-2020, 10:24 AM   #8
shew01
shew01's Avatar
Sorry, what does HF mean?
Old 04-07-2020, 10:56 AM   #9
1931 flamingo
1931 flamingo's Avatar
Harbor Freight.
Paul in CT
Old 04-07-2020, 02:52 PM   #10
shew01
shew01's Avatar
Originally Posted by 1931 flamingo View Post
Harbor Freight.
Paul in CT
Thanks.
Old 04-07-2020, 02:58 PM   #11
shew01
shew01's Avatar
Is this the one you purchased? https://www.harborfreight.com/portab...cer-39741.html
Old 04-07-2020, 04:04 PM   #12
old31
Yes thats it, and It works pretty darn good. With the 20% coupon its $67.99.
Get some of these as well. The quarter oz. fit better on the lip of the rim.
https://www.harborfreight.com/1-4-qu...hts-67225.html
Old 04-07-2020, 05:37 PM   #13
shew01
shew01's Avatar
Thanks for the coupon reminder and the link to the weights. I never thought about Harbor Freight having wheel balancing products.
Old 04-07-2020, 08:29 PM   #14
Y-Blockhead
Y-Blockhead's Avatar
old31, I have beads in my tires and they seem to work great. 4oz. as you stated. And yes you have to have a lot of patients but I got them in.
Old 04-08-2020, 04:23 AM   #15
shew01
shew01's Avatar
How did you get them into the tire? One glass bead at a time?
Old 04-08-2020, 11:08 AM   #16
rocket1
I have heard that you never want to reverse the rotation of a radial tire.
rocket1 is offline   Reply With Quote
Old 10-26-2021, 06:04 PM   #17
nkaminar
nkaminar's Avatar
I just rotated my tires. LF switched with RR, RF switched with LR. My rear tires have had a lot more wear than the front. I have a 1930 Fordor with a heavy metal trunk that I keep my tools in and the spare wheel mounted aft of the trunk. Is it usual for the rear tires to wear more than the front? The front tires are bald now (I have new tires on order) and it makes the car wonder and be more susceptible to undulations in the road.
Plus, What is the answer to Rocket's question about radial tires.
Old 10-26-2021, 06:29 PM   #18
Synchro909
Synchro909's Avatar
I've been told that too and that the walls don't like it but I'm sceptical. If we consider the rear tyres, they are driven in one direct by the motor, then driven in the other when the brakes are applied. Forward and back, forward and back many times a mile in the city. I don't think it matters much but who am I to say.
I'm part of the only ever generation with an analogue childhood and a digital adulthood.
Old 10-26-2021, 06:32 PM   #19
Keith True
Keith True's Avatar
In the mid-70's the tire reps drilled into us to only move the new radial tires to keep the same direction of rotation.Left stayed on left and right stayed on right.15 years later I was talking to a tire rep and asked him about it.He said the technology had changed,and we were supposed to rotate tires like you did with the old bias ply.Old habits die hard,the only thing new radials have in common with old radials is the name radial.
Keith True is offline   Reply With Quote
Old 10-27-2021, 06:30 AM   #20
nkaminar
nkaminar's Avatar
Thanks for the comments about the radials. Much appreciated.
What about the rears wearing faster than the fronts? Have you seen this too? Or is just the way I am driving?
