08-15-2016, 10:22 PM | #1 |
Steering Damper
We were away for the weekend in our '28 Tudor and for the first time, it showed signs of wanting to wobble at low speed. I've gone trough the front end and all looks very good except maybe a bit of play in the steering box. There is about 1 - 11/2 inches at the rim of the steering wheel.This steering box was done up only about 5 years ago and had NO play in it then. It is such a @#$%^& of a job to take the column out and put it back that rebuilding it again doesn't appeal, besides, I'm not interested in doing it yet again any time soon.
I've heard all of the arguments about how dampers only disguise a problem and I don't really want to hear them all over again please. I've looked in catalogues and can't see them listed. Are they still available? What have others done? PS. I would have no objection to putting a 2 tooth column in if I could get one. They're as scarce as rocking horse $#!T. (RHD)
08-15-2016, 10:28 PM | #2 |
Re: Steering Damper
If you mean "the death wobble" where you hit a bump and the front tires shake rapidly back and forth, I'd first make sure the toe in is dead on.
08-15-2016, 10:32 PM | #3 |
Re: Steering Damper
Thanks Tom. There is no bump involved, it just appears at low (walking) speed, usually as I am coming to a stop.
The toe in appears to be OK. The wobbles just started with no change to the toe in or anything else since the last few thousand miles and the tyres look to have even wear. Bill, Does the dog have any answers???
08-15-2016, 10:46 PM | #4 |
Re: Steering Damper
If it's in your mindset, you can use a 56 Ford pickup box that is modified. I did that after I had a 7 tooth rebuilt by an "expert" and it lasted about four years then I got the play back in the wheel. Well worth the cost to me as I can now turn with one finger if moving at all. That saves my foul back a lot of pain on long trips. The steering damper I had on my truck bent the tie rod, put a brand new one on and it got bent in no time, so I took that off. Just what has been my experience. Past performance is no guarantee of future gains...no, that's something different, isn't it?
08-15-2016, 10:57 PM | #5 | |
Re: Steering Damper
I only know about DOG trackin' & TOE IN/TOE OUT Be sure to check them NUTS that hold the steering arms to the spindles. Daves' "TUDOR FROM HELL," had a low speed side to side wobble, whin his nuts were loose Make them REAL TIGHT!!! And make SURE it's NOT tyre or wheel run out. Buster T.
08-15-2016, 11:15 PM | #6 |
Re: Steering Damper
Check the caster. My rebuilt 7 tooth also have a little play which becomes quite scary at speed. I was just as dissapointed as you until I rechecked the toe and caster. Toe was fine, but the caster was out. In order to change the caster, I added another spring blade to raise the front end. The caster is now within spec and problem solved. If you are satisfied with the spring setup, just add a 6 inch off cut piece on top iso an extra blade. Tips, 1. load a free inclinometer app on your cell phone 2. use the one in sixty rule to calculate the thickness of the spacer required 3. the wishbone is about 800mm from ball to axle
Regards Chris Cape Town 28 Model A RPU, 29 Chevy Phaeton, 67 E Type FHC, 67 250SL Pagoda, 83 911 SC |
08-15-2016, 11:18 PM | #7 |
Re: Steering Damper
I put a damper on my '29 Tudor 30 years ago and have never taken it off. I have experienced NO adverse effects from that. Someday I'll replace my wishbone and rebuild the front end, but until then...
08-15-2016, 11:53 PM | #8 | |
Re: Steering Damper
Looks like problem solved. Arizona Model A has come to the rescue AGAIN. Sammy is a very knowledgeable and helpful guy. Thanks to all who responded
08-16-2016, 12:02 AM | #9 |
Re: Steering Damper
Synchro909, RHD F100 box totally different to the LHD one , Coming soon from Flat Head TED new 30-31 s/box with F100 guts , I have a complete rebuilt RHD Gemmer here, Also steering Dampers in stock . sounds like you are fixed up.
08-16-2016, 12:34 AM | #10 |
Re: Steering Damper
My guess is 99.9% of all Model A's on the road don't have the low speed wobble. The best thing is to find the true problem and fix it. But it is your cr to do with as you want. How about a Mustang front end? All the future problems of the A front end would be gone.
08-16-2016, 12:35 AM | #11 |
Re: Steering Damper
Sometimes loose ball joints especially on the tie rods will do it. Also check wheel bearings and King pins.
08-16-2016, 12:58 AM | #12 | |
Re: Steering Damper
Ford has only started selling Mustangs again here in the past couple of months after a break of decades. Second hand front end? Not likely.
08-16-2016, 01:38 AM | #13 | |
Re: Steering Damper
08-16-2016, 04:55 AM | #14 |
Re: Steering Damper
Do a tire rotation and retest. It's quick .. Air them up also
08-16-2016, 07:32 AM | #15 |
Re: Steering Damper
I would check those steering arm nuts for tightness as Bill W. suggested. The right steering arm on my coupe had loosened I don't know how as these are large nuts with cotter pins. The shaft diameter or the hole in the axle behind the nut can wear and allow the shaft to wobble slightly which gets exaggerated at the wheel.
08-16-2016, 08:28 AM | #16 | |
Re: Steering Damper
That's why the Dog posted that. Those nuts are OFTEN overlooked & have to be REALLY TIGHT, like Dicks' HATBAND! The Dogs' Man
08-16-2016, 08:38 AM | #17 |
Re: Steering Damper
So what was the problem, and how did you fix it?
08-16-2016, 08:38 AM | #18 |
Re: Steering Damper
Make sure the A frame bolts are tight where it attaches to the bell housing. If you placed a rubber ball in there when you redid stuff years ago it might be worn out.
08-16-2016, 08:40 AM | #19 |
Re: Steering Damper
Synchro909,
One of our members suddenly developed a low speed wobble and it turned out that his front drums were out of round. He had the drums trued up and the problem was fixed. Al |
08-16-2016, 08:57 AM | #20 |
Re: Steering Damper
be sure the kingpin lock pins are tight
'31 180A |
