08-15-2016, 05:58 PM | #1 |
Marvel Schrebler carburetor
I noticed gas weeping from a small hole just above the GAV adjustment and where the bowl meet on my carburetor. Where the dark spot is. The car runs fine. Could it be a float problem? Or something else? In the picture there is a bright spot on the carb. bowl that's from a light, not wet with gas.
31 Tudor 66 Bonneville 57 Chevy pickup 27 T roadster pick up |
08-16-2016, 12:37 PM | #2 |
Re: Marvel Schrebler carburetor
Hi John
That small hole is the float bowl vent. You may have a weeping float valve. Here's a link to some information: http://www.fordbarn.com/forum/showth...ght=dissection Jeff |
08-16-2016, 03:46 PM | #3 |
That red washer on the GAV doesn't belong. The Marvel uses a seal on the GAV needle, unlike the Zenith and Tilly carbs.
Renners Corners has parts for the Marvel. |
08-16-2016, 04:33 PM | #4 | |
Thanks
