08-12-2016, 10:22 PM | #1 |
Model A Wheel to 17" Wire Wheel Swap Question
Hi All,
Question - I had heard that 16" and 17" Ford wire wheels would fit a Model A. As I was scouring for information, I read something about "AR" Model A's not being able to because of their hubs. I have a '28 roadster with the "AR" items like the red steering wheel and the emergency brake placement. Can I swap my 21" wheels for a set of 16" or 17" wires, or will I need new hubs? Also! If anyone has a picture of a full fendered A with the 17" ('33/'34 ford) wires, I'd love to take a look. All help is greatly appreciated!! |
08-12-2016, 10:28 PM | #2 |
Re: Model A Wheel to 17" Wire Wheel Swap Question
yes the "Early" '28 have a shallower depth center hub but later 28-29 (21")will be standard as 30-31 (19") along with other later Ford wheels having the 5 hole configuration. 1932 were 18" then 33-34 were 17" and I believe 35-36 were 16".....anyone else care to elaborate ?
1928 "A" Phaeton (mid year with many early features) 1933 "V8" Closed-Cab Pickup Truck (originally a Model B, 4 Cylinder dating to May, 1933)
08-12-2016, 10:34 PM | #3 |
Al it sounds like you get it. alvisoroadsters you should search the forum for the E28 wheels posts I'm sure there are pictures for you to be 100% sure of the wheels you have.
Where is your parking brake, on the left?
08-13-2016, 01:55 AM | #4 |
Will do - the parking brake is on thr right, but I believe it's in a different place than sat the '30/'31S?
What should I be looking for at the wheels to verifywhether the hub is AR or not? |
08-13-2016, 04:50 AM | #5 |
How many brake rods run to each rear backing plate?
The early 28's only have one, and the parking brake handle is on the left by the door post. |
08-13-2016, 07:33 AM | #6 |
The AR has hubs that look model T like- about 1 1/8" thick. the newer hubs are closer to 1 1/2". |
08-13-2016, 03:05 PM | #7 |
sometimes looking things up in the archives is not as easy at it sounds. Here are some pictures that might help.
First pix the area between the arrows is 3/16" to 1/4" narrower than and A wheel. AR 1 1/8 " across. A wheel 1 3/8" across. approx. measures. Hubs are also didfferent. |
08-13-2016, 03:43 PM | #8 |
Great call - measured the section you've indicated with the arrows, and I have 1-3/8" in the same section.
This would indicate the hubs are not AR, and I'd be fine with running 16" or 17" ford wheels, is that right? |
08-13-2016, 07:04 PM | #9 |
Tom - two rods running to the back hubs.
Ken's info was great, confirmed I've got A wheels. Would that mean that a set of 16's are bolt-on possibilities? Thanks! |
08-13-2016, 08:25 PM | #10 |
A 16" 1935 Ford wheel is a direct bolt up to a stock (not AR) Model A Hub and drum. I cannot speak for 17" wheels, 'cause I have never put any on a car.
08-13-2016, 09:20 PM | #11 |
(32) 18's and (33-34) 17's will also bolt right up to the late 28-31 Model A hubs. Same as with the (35) 16 inch wire wheels.
Chris W. |
08-14-2016, 11:13 AM | #12 |
Location: Barren windswept mountain somewhere in bleak Northeastern Pennsylvania
Back in the 1930s, there was much of that Model A Ford wheel swap action going on. Decades ago, we used to run across many A models with 16 and 17 inch V8 Ford spoke wheels installed. To knowledge, the things bolt right on.
I wouldn't be so paranoid if people weren't plotting against me all the time |
08-14-2016, 07:01 PM | #13 | |
Charlie Stephens |
