Old 08-12-2016, 03:36 PM   #61
tinkirk
tinkirk's Avatar
Default Re: Engine power
they sell cast plugs I believe in a kit form to repair such things, find a machine shop and see what they can do with it
tinkirk is offline   Reply With Quote
Old 08-12-2016, 04:13 PM   #62
Mitch//pa
Hooray that was a fun adventure.. Glad you finally found it
Old 08-12-2016, 04:31 PM   #63
harleytoprock
I guess I nailed it in post #7. LOL. Did I win anyhing? LOL
I'm glad you can sleep better tonight. Best wishes on the repair.
harleytoprock is offline   Reply With Quote
Old 08-12-2016, 05:08 PM   #64
Mitch//pa
Yes u did,, it's the same thing u got when you became a senior member at 100 posts...
Old 08-12-2016, 06:27 PM   #65
Tom Wesenberg
Tom Wesenberg's Avatar
Now, what make it crack?
Be sure to throw your torque wrench in the drawer, and just use common sense.
If you use the steel rings, make sure the recess is deep enough so the gasket is tight before the rings are tight.
Old 08-12-2016, 07:24 PM   #66
zzlegend
zzlegend's Avatar
Depends???????????????????????????????
zzlegend is offline   Reply With Quote
Old 08-12-2016, 07:30 PM   #67
harleytoprock
I'm so old, I don't buy green bananas. But I don't need depends yet.
Old 08-12-2016, 08:16 PM   #68
tbirdtbird
a very interesting development indeed. Never saw a manifold crack there
'31 180A
tbirdtbird is offline   Reply With Quote
Old 08-12-2016, 10:31 PM   #69
Flathead
Flathead's Avatar
Over tightened and cracked. I have seen it with aluminum "Hot Rod" A intakes.
Flathead is offline   Reply With Quote
Old 08-12-2016, 11:40 PM   #70
Mike V. Florida
Mike V. Florida's Avatar
So glad it is solved!
Old 08-13-2016, 05:06 AM   #71
Tom Wesenberg
Default Re: I think I found it
Originally Posted by Bob Johnson View Post
Tom you were right. I sprayed starter fluid around the intake and I got a speedup. I found a crack in the intake manifold. This did not show up with my first leak test because I was only looking at the gasket, my bad. Now I have to find another B manifold, open up an A manifold, just use an A manifold or ....
Bob
The picture has me wondering about the counterbore for the steel ring.
Did someone use a thin ring to fill in the counterbore?
Old 08-13-2016, 05:00 PM   #72
Bob Johnson
Bob Johnson's Avatar
Tom that is the B intake manifold. I do not think they had counter bores. What you see is the impression made by the steel part of the gasket.
Bob Johnson is offline   Reply With Quote
Old 08-13-2016, 05:24 PM   #73
Bob Johnson
I just finished resurfacing the old exhaust manifold with a spare A intake manifold. It took some time to get it lined up on the mill because the exhaust manifold was warped. I squared it on the mill using the middle two exhaust ports as a reference because they seem to be close to level. I had to remove 0.020" from the end exhaust ports. And there was a 0.010" difference in the top and bottom of the end ports. This is likely the reason for the crack in the intake when I torqued it down. Yes I should have checked the manifolds before I installed them but it was a pair that just came off an engine. They had been resurfaced a couple of years ago so I assumed they were OK. Bad assumption. A guy in the local club has a setup to bore the A intake to B size. I am going to ask him to bore it out for me. Then cross fingers and slap it all back together.
Bob
Old 08-13-2016, 09:01 PM   #74
Tom Wesenberg
I've heard B blocks are prone to crack due to thin castings.
I wonder if your B intake was also thin and cracked easier due to thin castings?
Old 08-13-2016, 11:21 PM   #75
Tom Foster
Here's a thought. We had a club member repair a water jacket crack in a B block was JB Weld and steel wool. Drove the car to Alaska and back that way. The intake manifold would be hot but not carrying combustion gases. Might be something to try, if you don't want the A manifold.
Tom Foster is offline   Reply With Quote
Old 08-13-2016, 11:47 PM   #76
Bob Johnson
The crack is on one of the ears. I do not think JB weld would be able to take the torque.
But thanks for the suggestion.
Bob
Old 08-14-2016, 12:16 AM   #77
Mike V. Florida
But tanks for the suggestion.
Bob
Brazing as an experiment to see if it works?
Old 08-14-2016, 12:32 PM   #78
Tom Foster
Bob
Oops. From the picture I thought it was in the flow passage. You're right about the ears not being able to hold.
