02-02-2016, 07:49 PM | #1 |
armrests
in a foor door how are the rear side armrests located. There was nothing in the body i brought and it doesn't seem to have any wood to fasten the rear of the rests
Jimmy Palmer |
02-02-2016, 08:05 PM | #2 |
Re: armrests
There is a steel formed bracket, that has an opening towards the front that the armrest slides into. Additionally there is a screw through the rear of the armrest, which gets hidden by the seat back.
Brian French; 1930 Briggs Town Sedan Last edited by Brianfrench65; 02-02-2016 at 08:08 PM. Reason: Added picture |
02-03-2016, 05:53 AM | #3 |
Re: armrests
JD
You did not say what car you have, on my 31 S/W town sedan they are screwed through the rear quarter panel in to the wooded frame of the armrest and covered with fabric and padding. Richard in New Bern When everything seems to be going against you, remember that the airplane takes off against the wind, not with it” - Henry Ford |
02-03-2016, 04:06 PM | #4 |
Re: armrests
Did the standard fordoors come with armrests?
Mike
1930 TownSedan (Briggs) 1957 Country Sedan Last edited by 1930artdeco; 02-03-2016 at 04:14 PM. |
02-03-2016, 04:34 PM | #5 |
Re: armrests
From what I understand, the standard 4) doors, had a center round dome light, with a switch built in, no rear seat armrests (center or sides), plain window frames, with painted pulls, and no cowl lights.
Brian French; 1930 Briggs Town Sedan |
02-03-2016, 04:37 PM | #6 |
Re: armrests
The front slides in first from front to back then the back of the arm rest is secured with the screw. I don't think the standard Fordors had rear armrests. |
