Old 08-14-2020, 12:23 PM   #1
Nsieber
Default 60 Amp Alternator
Has anyone ever purchased and installed a 60 amp generator from Millworks Hot Rod and Supply Co. before? I am having an issue with the tensioner bolt that is supposed to thread into the timing gear cover. Could someone with this alternator kit measure the length/diameter of the mounting bolt supplied for the tensioner bracket? Thank you! Nick
Nsieber is offline   Reply With Quote
Old 08-15-2020, 07:41 AM   #2
chap52
chap52's Avatar
Default Re: 60 Amp Alternator
Can you call Millworks? They may send you a new bolt. Just a thought. Chap
