08-13-2016, 04:43 PM | #1 |
31 rdster carb results
Ok so here is where I stand,after many tries with shims and slight bending of the float [ to keep the 5/8 in. float height ] I was able to stop the leak. I used the site tube with a 5/8 mark on it from the gasket between the 2 halves,as suggested. now when I started the engine I was getting a popping from the carb, from what I ' ve read that means the gas level in the carb is too low?? so now what do I start removing shims from under the seat?? and start over? please advise . thanks THE HOOCH
08-13-2016, 05:31 PM | #2 |
Re: 31 rdster carb results
www.whidbeymodelaclub.com |
