Old 10-03-2020, 11:15 AM   #1
56sedandelivery
56sedandelivery's Avatar
Default Inner fender to fender anti squeak rubber
Which way does this rubber go? It has a wide side and a short side with about a 20 degree bend. In the pic I would guess that it is pic number 4 with the short side on the engine bay side. but not sure. Anyone know for sure?
56sedandelivery is offline   Reply With Quote
Old 10-03-2020, 02:50 PM   #2
Hot Rod Reverend
Hot Rod Reverend's Avatar
Default Re: Inner fender to fender anti squeak rubber
ask and ye shall receive...
https://www.hotrodreverend.com/post/...n-blog-part-13
Lancaster, California
Visit hotrodreverend.com to view hundreds of pictures and videos of the build of the 1955 Ford Club Sedan!
Hot Rod Reverend is offline   Reply With Quote
Old 10-03-2020, 05:59 PM   #3
Daves55Sedan
Daves55Sedan's Avatar
When I did mine (both '55's), I laid the long side on the fender apron flange with the short side sticking upward to mate with underside of fender. Aim the short side so it is facing up or forward like HRR's photo showed in his blog.
Also at the corner, I mitred the corner so the rubber does NOT overlap to insure an even seal all across.
Daves55Sedan is offline   Reply With Quote
Old 10-04-2020, 03:39 PM   #4
56sedandelivery
Just what I needed. Thanks guys
Old 10-06-2020, 06:03 PM   #5
56sedandelivery
Question on staples. Can you use regular staple gun T50 staples or are they too small in diameter? I have some stainless staples but do not know if the diameter is large enough.
