07-26-2016, 01:37 PM | #1 |
Tappet adjustment
Trying to adjust the tappets, see picture below. The nut is split which would indicate that it is self locking. But the top of the tappet just below the nut has flats for a wrench. I tried holding the tappet and backing off the nut. I did not apply a lot of force but the nut did not move. If I hold the nut with a wrench the "bolt" turns with some resistance, but less than I would anticipate for a self locking nut. How are these adjusted? Should I use some thread locking fluid ?
Bob |
07-26-2016, 03:26 PM | #2 |
Re: Tappet adjustment
All the locking nut tappets I have seen, do not have a split in the nut. I believe that is a broken nut. You should not be able to turn the bolt with the nut seated on top of the tappet. You put a wrench on the tappet flat, with the second wrench loosen the lock nut and then make the lash adjustment. It is a tedious project with very thin wrenches to get everything done. When you do, they stay the way you left them.
Heck of a photo by the way! |
07-26-2016, 04:03 PM | #3 |
Russ (above) is describing the "3 wrench" tappets. Be aware that there are "2 wrench" tappet (self locking) systems - and that at least one of these has a "slot" similar to what you see in your most excellent pictures.
Opinions vary as to which of the two systems is best. I, familiar with the 3 wrench system asked my engine rebuilder (Knight Automotive of Kettle Cove, MA) to use that. He explained at length that he preferred the 2 wrench system which he felt more reliable, easier to adjust, easier to correct, and half a dozen other reasons to stick with his recommendation. I ultimately relied on his judgment. Perhaps you know your engine source and can tap them for further knowledge? Unless somebody here can recognize your lifter? Joe K
Shudda kept the horse. |
07-26-2016, 04:26 PM | #4 |
X2 what Russ said
07-26-2016, 05:04 PM | #5 |
Well that's easy to figure out, do the other lifters have a split nut?
07-26-2016, 05:10 PM | #6 |
07-26-2016, 06:12 PM | #7 |
Yes all the nuts are split.
07-26-2016, 06:31 PM | #8 |
I think that is the locking tappet. It is not just a nut it has a tapper on it that goes in a tapper in the lifter. If you look close you will see where there is a half a hole at the top where they started the split.
07-26-2016, 07:29 PM | #9 |
I set mine at .012 intake and .015 exhaust.
07-26-2016, 08:29 PM | #10 | |
IIRC, the 2 wrench tappets used on my motor were of the "nylock" type. But I have not had occasion to adjust them. They seem fine as they are for now. Joe K
07-26-2016, 09:36 PM | #11 |
Interesting! Never saw those, but I haven't been in the Model A world for very long.
07-27-2016, 09:56 AM | #12 |
In the tappets pictured, the split nut is a jamb nut, and may require some torque to loosen. Be sure to tighten firmly. I've only seen one other set like this but they should be good. I set the clearance of a stock cam at .012" and .014".
07-27-2016, 10:15 AM | #13 |
If it is a jam nut then the tappet must be threaded? Why would the jam nut be split? If the nut is tightened too much would the split open? I was able to adjust the "bolt" without opening up the "jam" nut. Is that normal?
Bob |
07-27-2016, 10:57 AM | #14 |
That's not really a 'jam nut'as we know them.It is more of a hollow bolt,threaded on both the inside and outside.One of the parts has a slight taper,although I can't remember which one.When you get the clearance where you want it,with the top bolt,you hold the top bolt,the tappet,and turn that jam bolt down with your third hand.That taper closes up the split and squeezes against both the adjusting bolt and the tappet.The jam bolts on mine though don't thread in far enough to bottom out on the tappet like the one in the picture.Somebody got carried away tightening,or it was made wrong to begin with.The top of the tappet could also be recessed enough for the hex to drop into a little too.
07-27-2016, 11:10 AM | #15 | |
