03-19-2013, 08:41 PM | #1 |
Oil pan gasket question from a newbie
I bought a 31 Tudor last spring and I am learning more and more about them all the time. Reading all the post has given me a lot of insight and questions. Some a little late of course but its all a part of learning.
I've been fighting an overheating issue from the time I brought it home. A chemical block test has shown that I have exhaust gas getting into my cooling system so I bought a used motor to put in it. I'm hoping it will get me by until I can rebuild the one I'm taking out. I wanted to see what the inside of the used motor looked like and if it had any improvements done to it. Its clean with no sludge and original style bearings and valves. I have dropped the pan and removed all the gasket material (I didn't know about the tabs on the pan gasket until I read it in one of the threads) and put a new timing gear in it. Ive got Les Andrews manual as a guide to work on it but am unclear on one little detail. The book states that the rope like packing should be oil soaked and left untrimmed before you put it in the pan and timing cover. Now my question is what is meant by oil soaked? Should I put the packing in oil to soak for a few days or just coat them good before installing them in the motor? Do I need to trim them after I put them in or will they crush to fit? I know it sounds like dumb questions but I am finding that some of the engineering on these motors are nothing like I've ever seen before. I have also noticed that the pan on the used motor is a newer style and the old motor is an early 28 pan with the clean out plate. Should I use the older style pan? It sounds like it is preferred from reading the forums. Will the shield on the newer pump even work in the older pan? |
03-19-2013, 09:49 PM | #2 |
Re: Oil pan gasket question from a newbie
In regards to your first issue on the engine overheating and exhaust gases in your coolant have you considered pulling the head and replacing the head gasket first? If you don't have any cracks and it is flat that might be the only fix you need. Be a heck of a lot simpler that swaping out engines. Another thing that might be contributing to over heating is a build up of rust particles etc... in the top tank of the radiator blocking the tubes. Have you tried pulling the radiator out and back flushing it?
Dave / Lincoln Nebraska |
03-19-2013, 10:38 PM | #3 |
Soak them in motor oil overnight and the seal halves will then be able to crush down without trimming.
03-19-2013, 10:44 PM | #4 |
I do the same as Milton. No problems.
03-19-2013, 11:36 PM | #5 |
If you mean the shield that fits betweenthe oil pump & block,then you should use the 31 pan.In late31 the dipper tray was lowered 1/8" by raising the bead in the dipper tray by 1/8".The shield should not be used with the earlier dipper tray.The pan with the clean-out plate was a 1928 feature and the extra gasket is another potential oil leak.
03-20-2013, 04:05 PM | #6 |
03-20-2013, 04:21 PM | #7 |
According to a report in the Model A Times, the 4 blade fan will do nothing for your heating problem. You may want it for other reasons.????????????
03-20-2013, 04:33 PM | #8 |
Are you sure you have the timing right on. If to slow it will cause it to heat.
03-20-2013, 04:53 PM | #9 |
Do a search . Nine times out of ten it is a bad radiator . Radiators can flow great but if the fins are not connected to the tubes there will be no heat transfer .
03-20-2013, 04:58 PM | #10 |
on your pan gaskets . the white one (front) does need to be soaked like over nite .
the rear (cork) soak it in water so it will bend correctly .
V4f |
03-20-2013, 05:54 PM | #11 |
sidhartha: So you've changed the head gasket, waterpump and added a t/stat, BEFORE you go changing engines, make sure the timing is set correctly AND that when driving your advancing the timing (left lever on the steering column). Get the new radiator that you were going to install with the used engine (or flush the original one). FWIW
paul in CT |
03-20-2013, 07:07 PM | #12 |
Did you have the head magna-fluxed and surfaced by a machine shop to insure it is flat and has no cracks ? Check the deck surface of the block also for cracks since getting combustion gasses in the water is really the source of the overheating problem. When installing the head it must be torqued in sequence and in progressive amounts. Always use a new gasket. Also check the impeller on the water pump to see if it is worn.
03-20-2013, 08:43 PM | #13 |
Thanks for all the suggestions. It has a New Rex Electronic ignition on it and I have set and reset the timing with the New Rex timing wrench. My early mistake was not operating the timing advance properly, but now I know how to work that I still have the same problem. The old copper head gasket showed no sign of burning between the water jackets and combustion exhaust port areas. I checked the deck and head with a 3 foot straight edge and they are flat. The head is 5.5:1 compression newly purchased from Snyders and is installed with a model B (not Copper) head gasket. since it was new I did not Magna-flux it. The water pump is also new as well. I am using the 4 blade fan because it came on the used motor and I figured if it moves more air it couldn't hurt. The old motor has been hot several times. The guy told that they had a problem with it overheating while in parades. Of course I was caught up in the purchase of the car and it did not register. It might be to good to note that I am not I am not getting oil in the water or water in the oil. I should mention to that I flushed the system and put some CLR through it, but I wouldn't think that could have hurt anything. I may just change the radiator this weekend and see what that does. The other motor is on the stand so I will go ahead and put it back together and have it ready if I need. maybe take some time and install a touring cam as well.
03-20-2013, 09:00 PM | #14 |
I had the same problem, and did everything I could think of except the radiator. Everyone in my club kept telling me to replace the radiator including Les Andrews. I finally gave in and got it recored. It runs cool without problems now. I just was overlooking the obvious. Don't forget to re-torque you head at least 3 to 4 times.
03-21-2013, 11:29 AM | #15 |
"A chemical block test has shown that I have exhaust gas getting into my cooling system " Could be a crack in the exhaust seat allowing the exhaust to push into the cooling system. It can be fixed by pinning and valve seat replacement but may be more work then you want to spend. If you want to save the old block then it needs to be cleaned and pressure tested.
03-21-2013, 10:04 PM | #16 |
No need for a 4-blade fan.It will only make it dificult to remove the water pump at a later date.Get the alum fan sold by the vendors & it will look original.Because of the cost of a recore or new rad most people seem to try everything else before they bite the bullet & replace the rad & cure the problem.Also the block should be flushed out as well.
