Old 02-17-2020, 07:20 PM   #1
Benson
Benson's Avatar
Default Harbor Freight tape measures come up short
FYI
Last Friday the guys at Geezer Coffee were discussing Harbor Freight tape measures.
One guy found one TAPE that was not accurate.
The parts he measured did not fit after he cut them.
It seems that some of tapes come up short so it might be nice to check the tape measures for accuracy.
Old 02-17-2020, 07:39 PM   #2
gary678*
Thumbs down Re: Harbor Freight tape measures come up short
I've had a few that were given free with other purchases. All broke after a few uses. I don't like using this term, but they are "junk"!
gary678* is offline   Reply With Quote
Old 02-17-2020, 07:39 PM   #3
39portlander
39portlander's Avatar
Default Re: Harbor Freight tape measures come up short
Well this RULES out the old saying "measure twice, cut once"
39portlander is offline   Reply With Quote
Old 02-17-2020, 07:39 PM   #4
johnneilson
But, "I cut it off 3 times and it is still too short"
As Carroll Smith wrote; All Failures are Human in Origin.
johnneilson is offline   Reply With Quote
Old 02-17-2020, 07:44 PM   #5
Oldbluoval
Oldbluoval's Avatar
Would work if you measure then measure the cut with the same tape....
Maybe!! But maybe not!!
Old 02-17-2020, 07:48 PM   #6
updraught
updraught's Avatar
Measure from both ends and what is left in the middle, halve it,
For those who are cheap...
updraught is offline   Reply With Quote
Old 02-17-2020, 07:55 PM   #7
39portlander
Wait a minute, were these Geezers drinking coffee or just might there have been something in that coffee, something here does not ADD up
Old 02-17-2020, 08:31 PM   #8
David R.
My Dad had that experience a few years ago building an out building. He had two rules. One a bargain store brand and a good name brand one. After cutting up a lot of lumber that didn’t fit and thinking he was losing it, he finally stretched the two rules out side by side. The bargain job might be on at three feet, a quarter inch off at six feet and so on.
David R. is offline   Reply With Quote
Old 02-17-2020, 08:31 PM   #9
Bob C
That's what I have to do if I use a HF tape. I checked mine and it seems
to be off right at the end with the hook.
Bob
Old 02-17-2020, 09:11 PM   #10
Bill G
Bill G's Avatar
Starting at the end with the hook is ok if you’re measuring drywall or planks for a patio, but for more accurate measurements I always start at the one inch mark. Just don’t forget to add an inch on the other end!!
Old 02-17-2020, 09:37 PM   #11
Phil Brown
Phil Brown's Avatar
Yep, that's right, measure and cut with the same tape and it does not matter how far it's off. It will be off the same amount both times.
And when you compare it to another tape, how do you know which one is the one that is off ?
Phil Brown is offline   Reply With Quote
Old 02-17-2020, 10:36 PM   #12
daren007
Easy. Just send in your tape for "Calibration".
daren007 is offline   Reply With Quote
Old 02-18-2020, 08:46 AM   #13
77Birdman
I am a 4th generation master carpenter and wouldn't think of using a hf tape. I have used Stanley for 40 yrs now, through in the occasional craftsman. But this reminds of a couple of stories. Recently my son, whom works with me, and I were having trouble with installing some ceiling boards. It seemed that every other cut was off. I kept giving him the devil because it couldn't be me making the mistake! Come to find out my poor old tape was the problem, end had come just loose enough to make a difference, into the trash it went.
In another instance I remember a story Pop told me, back in his day they would use stick rules. He said there was a guy that he worked with that always bought the cheapest he could find, all of the others used Lufkins, said they were never in sync.
77Birdman is offline   Reply With Quote
Old 02-18-2020, 09:37 AM   #14
woodiewagon46
The measuring tapes were perfect when they left China!
woodiewagon46 is offline   Reply With Quote
Old 02-18-2020, 09:59 AM   #15
Doodlebug1930
I agree that the HF tapes are of poor quality. However, with any tape measure occasionally check the hook end. It can get bent & will throw off your results when taking an inside or outside measurement.
Doodlebug1930 is offline   Reply With Quote
Old 02-18-2020, 10:47 AM   #16
Keith True
Keith True's Avatar
A new Harbor Freight store opened up near here on Saturday,and the first 1000 customers got a free tape measure.My friend got one,and was in my garage that night telling me that the tape was off.We held it up to a one foot machinest's rule,it was a little off.I had it in my hand and noticed the hook on the end was tight.I said that's not right,the hook is supposed to have a little play in it.He had assumed that because it was from China the hook was just loose because of poor quality.He had gone over to my brake rivet press and squashed the rivet down tight.He didn't know that the hook moved one way for a pull measurement,and moved the other way for an accurate inside measurement,and was OK to begin with.
Keith True is online now   Reply With Quote
Old 02-18-2020, 11:16 AM   #17
Joe K
Joe K's Avatar
I think its safe to say with Harbor Freight - your mileage may vary.
I was at the new HF store in Portsmouth (the same one mentioned by Keith) and bought a "carport shelter" in the 10x20 dimensions.
The dimensions ARE 10x20 - it covers my chicken run nicely and now the girls won't have to walk on snow (which they abhor!)
The top is a little "loose" compared to the Shelter Logic version we use for camping. Also the HF top "spaces out" the bungie ties for economy - and misses the four corners entirely.
The HF tubes & tees seem equal in thickness (Shelter Logics are not that thick anyway,) but surprisingly, the top is a little "taller" than the Shelter Logic.
Overall, I would say the $99 HF Carport ($160 equivalent Shelter Logic) was money well spent albeit it is only a chicken run cover.
Mostly I've had good experience with HF. I would NOT buy batteries or battery powered tools from them, however. Air hoses OK if you buy the upper end hoses.
Two wheelers you can expect the pneumatic tires to be flat within a week - and even the HF replacement wheels. (And surprisingly replacement tubes in the 4x8 size from almost all other sources including Amazon and AdvanceAutoParts - Chinese Rubber STINKS and is prone to early aging.) The HF solid rubber tires to fit the two wheelers seem good - and not too expensive.
As I say, your mileage may vary.
Joe K
Shudda kept the horse.
Old 02-18-2020, 11:18 AM   #18
Bob/AZ
Bob/AZ's Avatar
I haven't noticed a problem with their tapes but I do like the little blue magnetic flashlights they give away. I have three stuck to the fridge.
Bob/AZ is offline   Reply With Quote
Old 02-18-2020, 11:29 AM   #19
goodcar
Originally Posted by Benson View Post
FYI
Once had an annoying boss, didn't trust the help, had to measure everything we built. Got ahold of his tape measure and cut off the first inch, replaced the clip. Thought we were going to have to call 911 when he freaked out next time he started measuring our work---the joys of working for the railroad.
goodcar is offline   Reply With Quote
Old 02-18-2020, 11:51 AM   #20
Ted Duke
ALL tape measures are suspect. In 1968 we bought a new home in Virginia Beach. Needed shades on all of the windows (3 bdrm house). Picked up a CRAFTSMAN ruler at Sears and measured all of the windows, went back to Sears and ordered shades. Picked them up two days later they were all 1/4" short. Measured the windows again and went to Sear. They measured them and they were correct.
Salesman measured my Craftsman ruler, broke it it half threw it in the trash. Got a new one, measured it, handed it to me and said you blinds will be ready tomorrow by one pm.
No charge. All items you measure with may have an error; like GPS.
Ted Duke is offline   Reply With Quote
